Old 06-05-2009, 02:07 PM   #1
Problem with 5 light ceiling fan fixture
Light fixture on Casablanca fan has 5 lights. Four work perfectly and the fifth only works occasionally. Any ideas?
wetsu is offline   Reply With Quote
Old 06-05-2009, 02:12 PM   #2
DIY'r
ScottR's Avatar
Probably a loose connection in the lamp holder.
I'm assuming you tried a different bulb in the socket that's working intermittently?
ScottR is offline   Reply With Quote
Old 06-05-2009, 09:22 PM   #3
Electrical Contractor
Turn the breaker off, remove the bulb and pull the tap in the middle of the socket out a bit.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
Installing a new light fixture shorteared Electrical 2 12-27-2008 03:28 PM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 04:06 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
