Old 06-21-2011, 06:17 PM   #1
Unhappy
Problem with 230 volt double pole single throw switch
I want to install a DPST switch between a disconnect box and a well pump. I installed the switch and when the switch is in the"ON" position, the pump works fine. When I turn the switch to the "OFF" position, the relay in the disconnect box chatters (very rapid on-off) until I dosconnect the power. Any ideas sas to why the chatter?
rdempsey is offline   Reply With Quote
Old 06-21-2011, 06:57 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Post a schematic of how the switch is wired from the panel to the switch, to the relay, to the pump. If it is chattering, that means it is still getting voltage through current leak. What is the rating on the switch & relay?
gregzoll is online now   Reply With Quote
Old 06-21-2011, 07:04 PM   #3
Probably has something to do with the way the pressure switch is wired or whether its connections were disturbed when you installed the new double pole switch. I cannot speculate on it without seeing how the pressure switch and the relay are wired. Posting a picture of the wiring diagram (if there is one and it is still correct) can help.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-21-2011, 08:07 PM   #4
I=E/R
a7ecorsair's Avatar
Yes, you have it wired wrong
Is this a 240 volt pump? Why not interrupt the power before the pressure switch?
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
SD515 (06-21-2011)
Old 06-21-2011, 10:55 PM   #5
Idiot Emeritus
With most pumps, there cannot be any switch between the control box and the pump motor. If these lines are switched off, the start relay and that start capacitor will form an inductive-reactive circuit. Basically, they'll fight with each other. This is the chatter you're hearing.
The switch can be installed anywhere in the line from the panel to the control box, and it'll work fine.
Rob
micromind is offline   Reply With Quote
The Following User Says Thank You to micromind For This Useful Post:
gregzoll (06-21-2011)
Old 06-21-2011, 11:23 PM   #6
Missouri Bound's Avatar
We have a similar situation with a waterfall pump at my work. When it is powered down, the relay chatters. In our situation it is the pump running backwards when it is shut off as the water "backflushes". When the water is gone, the chatter stops. By design we do not use a check valve as this "backflushing" clears any debris around the pump.
Old 06-23-2011, 10:51 AM   #7
Rob
Rob, your answer fixed my problem. Thanks for the quick response - Rich
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 09:12 AM
duplex receptacle with single pole switch in bathroom cangert Electrical 8 04-26-2011 08:14 PM
Double 15 amp single pole mmacnz Electrical 6 04-17-2011 10:11 PM
Double pole breaker v/s single pole breaker schultz56 Electrical 3 02-09-2010 02:12 PM
Adding a single pole switch to 3 way switch. adrien2 Electrical 6 05-28-2009 03:44 PM
