This Probably Isn't To Code. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 10:56 AM   #1
This probably isn't to code.
Found this one in the attic yesterday shoved up under the insulation. Its a 12/3 + ground line that a guy very carefully cut the nm outer sheating off, then very carefully removed the insulation from two wires, then took an extension cord, cut the plug off, and wrapped it around the exposed wires.
Yikes, He had some little green thing plugged into the extension cord, and instead of just unplugging it, cut the wires and rammed it under the extension.
So my question, I use the plastic boxes at home depot but have never run a 12/3+ground wire. Usually just 12/2 and 14/2. So, is there any limitations on what size wire I can shove into one of these junction boxes? I know box fill calcs, but what about size the little folding cable clamp tabs can take?
Gonna have to split that add a couple of junction boxes and join them together I think.
B
b_corwin is offline   Reply With Quote
Old 01-30-2011, 11:14 AM   #2
Licensed electrician
Rewards Points: 1,028
The box clamps will be fine for the 12-3 or 14-3. Just use one cable per clamp.
You say you will need to split the box and then join it together. I hope that you are going to fix this correctly and remove the extension cord. Remember you need 6" of free conductor in the box. You may need to add 2 boxes with a short length of cable between to give you that much free conductor. Also the junction boxes must remain accessible.
Old 01-30-2011, 11:28 AM   #3
Yes to fixing it correctly. No way is that extension cord going to stay. By split I mean, remove the extension cord ( which goes no where anyway), mount each end in a box accessible and not covered in insulation, and then connect the two boxes with a new piece of 12/3.
A la my original statement of split and add some boxes. But that was a kind of ambiguous statement.
I was mainly just pointing out that I am continually amazed at the things I find.
thanks
b
Old 01-30-2011, 11:37 AM   #4
the Musigician
DangerMouse's Avatar
After what I saw inside MY old walls.... NOTHING here ever surprises ME!
DM
Old 01-30-2011, 12:48 PM   #5
joed's Avatar
Rewards Points: 11,588
If the 12/3 is not actually cut, there is no splice. Therefore no box required. Wrapping it properly with proper tape might be sufficient. Opinions welcome.
Old 01-30-2011, 06:54 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,858
I don't know whether that type of repair is code compliant or not, but it certainly can be done safely and that would be my solution.
mpoulton is offline   Reply With Quote
Old 01-30-2011, 07:17 PM   #7
Master Electrician
Rewards Points: 3,680
Turn off the power. Remove the staple in the upper part of the photo on the 3 wire. That will give you enough slack in the 3 wire to allow a proper splice in a j-box. Of course, discontinue use of the extension cord.
brric is offline   Reply With Quote
Old 01-30-2011, 07:41 PM   #8
joed's Avatar
I don't think that is a staple I think there are two cables going down inside a wall at that point.
Old 01-30-2011, 08:38 PM   #9
Master Electrician
I see you are probably correct. Damn good eyes.
Old 01-30-2011, 09:03 PM   #10
joed's Avatar
I looked at for some time trying figure out why they would loop it like that before I decided it was two cables.
Old 01-31-2011, 02:09 PM   #11
Rewards Points: 590
Some other smart person pointed out recently that NEC doesn't address repairs, only upgrades, mods, and new installations.
operagost is offline   Reply With Quote
Old 01-31-2011, 02:38 PM   #12
joed's Avatar
A repair would like for like replacement. Anything else would be a modification.
Old 01-31-2011, 04:36 PM   #13
Sorry Guys, yeah joed is correct that is not a staple but two cables going down into a wall.
B
2008 NEC Code & AFCI Requirement theatretch85 Electrical 5 03-12-2009 10:58 PM
Add shower to claw foot tub - code considerations? Leah Frances Plumbing 2 02-15-2009 01:55 AM
couple of code questions ponch37300 Electrical 9 01-26-2009 11:45 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
