Private Power Pole Farmer Fix - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 06:07 PM   #1
private power pole farmer fix
Getting ready to remove trees that interfere with my power lines goig out to one of my sub panels at a machine shed. One of the power poles is border line needing to be replaced. Looking at the trees there is one very close to the pole. Dumb question but is there codes that would stop me from leaving part of the tree trunck standing and attach the wires to the trunk of the tree I want to remove? Long term I want to go underground with the wire and dont feel like purchasing a pole at this time.
Thoughts?
grizzzlle is offline   Reply With Quote
Old 02-18-2013, 06:10 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Can't use vegatation. Dead or alive.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 02-18-2013, 06:11 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,498
Pretty sure it's NOT allowed !
dmxtothemax is offline   Reply With Quote
Old 02-18-2013, 06:50 PM   #4
Ok. How about cut tree down de bark it then sink it back in the old poles location. Just be giant pole at the base.
Old 02-18-2013, 07:08 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,970
You could, but it will rot eventually. Tree trunks don't hold up all that well. Poles are treated to prevent this. Why not just get a replacement pole? Used poles are available and usually fairly cheap.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 02-18-2013, 07:38 PM   #6
Honestly have not priced a new pole. Keeping an eye out on craigslist but my current pole sticks 20' up. Everything I have found so far is to short. Not sure if I really should be using a treated pole as the current location is close to my drinking well (not sure if there would be a leaching problem).
Old 02-18-2013, 08:56 PM   #7
$5 per foot for great condition, $2 per foot for worn out poles. That's one example from one source. Your local sources may be different, but that gives you a ballpark: a couple hundred bucks at most.
power pole retaining wall ididit Landscaping & Lawn Care 17 07-05-2015 05:41 PM
One Side of three 2 pole circuit breakers lose power intermittently River888 Electrical 30 07-02-2012 05:38 AM
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Power through outlet to two single pole switches aaronmoon Electrical 2 08-12-2009 08:29 AM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
