Primary Splice At Pole Mast - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 09:07 PM   #1
Primary Splice at Pole Mast
Is there any problem with this type of splice connection?
mk00 is offline   Reply With Quote
Old 04-23-2012, 09:13 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
A) That's not primary. It's secondary.
B) Yes, it is perfectly fine.
C) That is typically the property and responsibility of the power company. WHY do you ask?
Old 04-23-2012, 09:19 PM   #3
Rewards Points: 6,652
Only difference from mine, is that your neutral is not taped. So again, what is your question?
Old 04-23-2012, 11:44 PM   #4
dogris's Avatar
Needs a drip-loop before entry into the mast?
dogris is offline   Reply With Quote
Old 04-24-2012, 06:04 AM   #5
The pic is terrible. Could possibly have a great drip loop, it's just hard to tell.
Tags
primary
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 08:12 AM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-04-2012 11:07 PM
Double pole breaker used as single pole WonderingOne Electrical 11 11-30-2010 12:37 AM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
Service mast options bsperr Electrical 6 12-09-2009 08:48 AM
