Preventing Ovetheating Outlets From Christmas Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 07:17 PM   #1
Rewards Points: 117
Preventing ovetheating outlets from christmas lights
I only have one 15amp receptacle out front. One half feeds 200W landscape lights but I don't have the bulbs maxed.
That leaves the other half to feed the two photosensitive timers (6-outlet types) for everything else.
It's under 15 amps and I kept the max strands in series within the safety card in the package.
I just noticed while everything was being arranged in the yard the plug is too hot.
So, now that the layout is done I need a way to keep this cool.
All outdoor cords, timers, lights as well.
Would splitting between both halves of the receptacle work?
Thanks in advance.
Dornier is offline   Reply With Quote
Old 12-06-2012, 07:26 PM   #2
TTW
TTW's Avatar
What is the gauge of the extension cord you are using and how long is it?
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-06-2012, 07:40 PM   #3
Rewards Points: 117
The cord in question that became hot was the lead to the first of the two 6-outlet hubs with the photosensitive timer.
These are the two hubs I have: http://www.amazon.com/Master-13547-6...d_sim_sbs_hg_1
14/3 ga.
I mistyped earlier that it was the extension cord; I'm sorry.
The lengths vary from 10 to 25 ft to make things reach. The cords are the standard green outdoor types sold this time of year.
Old 12-06-2012, 07:50 PM   #4
Rewards Points: 258
how long is the cord that is getting hot
redman88 is offline   Reply With Quote
Old 12-06-2012, 07:53 PM   #5
Rewards Points: 117
6 ft according to the package although I didn't measure it exactly--seems accurate.
Old 12-06-2012, 07:58 PM   #6
TTW
TTW's Avatar
Try splitting things between both plugs in the receptacle and see if that helps.
Is it a GFCI receptacle?
Old 12-06-2012, 08:00 PM   #7
Rewards Points: 117
It's not a GFCI in itself, but it is downstream of one. I'll split them and see.
Old 12-06-2012, 08:05 PM   #8
Rewards Points: 1,548
A plug that is hot usually means a loose connection. Either the plug does not fit tightly in the receptacle or the loose connection is inside the plug (shoddy manufacturing) or inside the outlet box.
Old 12-06-2012, 08:07 PM   #9
Rewards Points: 117
Well, normally this receptacle only has one side used for the landscape light timer. Never noticed a heat issue.
I'll try splitting the hubs on both sides and test that first before pulling the it and checking the outlet.
Should be easy to test.
Old 12-07-2012, 05:09 AM   #10
Rewards Points: 117
Splitting the hubs and removing 2 strands worked fine. I guess I'll have to run two outdoor receptacles on their own circuit to keep the arrangement I have.
Thanks for the help.
Old 12-07-2012, 08:01 AM   #11
Rewards Points: 6,652
If you do not have AFCI breakers, you can get an AFCI outlet now through http://www.onestopbuy.com/mm/electri...cles-r1030.asp
Keep in mind that they are twice the cost as a GFCI outlet, but worth it if you cannot go through installing a AFCI breaker. As for overheating, the fuse inside the plug would blow.
Changed Outlets...Lights stay on... agentphish Electrical 4 03-29-2012 09:02 AM
Recessed can layout. outlets and number of breakers bryan1282 Electrical 6 12-30-2011 04:09 PM
Wiring multiple outlets, switches and lights Bubski27 General DIY Discussions 3 11-09-2011 06:54 AM
help with christmas lights!!!!! reds_21 Electrical 11 11-28-2007 10:02 AM
Wiring for external lights and outlets MikeinBurien Electrical 4 12-05-2005 12:16 AM
