-   -   Prevent Electrical surges with surge outlet? (http://www.diychatroom.com/f18/prevent-electrical-surges-surge-outlet-158052/)
tapr 09-26-2012 10:28 AM
Somehow two fuses tripped at once in our home. This has never occurred in the 18 years we have lived here. One line took out the power source on my desk top computer costing me $100 to repair. The computer repair person said line surges just happen and we have to put up with up computers being at risk. They see this situation and type of repair often.
I have read and been told a variety of things about sugre protectors not really being effective unless you spend at least over $35 up to over $100 on them. I have also read that once a fuse has been tripped the surge protector is probably no longer effective. I came across outlets that protects against power surges in my research as well. I have also wondered whether or not a computer needs it's own line like other home appliances? The computer repair person said this in all likely hood such an outlet would not have protected my computer and I need not bother with a separate line.
Can anyone address the above four issues or add any other information that would help me to avoid this situation again and protect my computer.
Thank you
kevinp22 09-26-2012 11:33 AM
1. fuses tripping have nothing to do with power surges. 2 fuses tripping at once suggests a problem in the wiring somewhere or a wierd periodic short circuit.
2. If the receptacle that the computer is plugged into is not grounded surge protectors cannot do their job. in that case, a new grounded circuit plus a reasonable priced surge protector ($40 and up) will serve you well. I like the ones with an indicator light showing that the circuit is grounded and protected. pay a little more and get one that protects phone and coax as well.
joed 09-26-2012 01:07 PM
Perhaps the computer supply going bad tripped the fuse and not the other way around. Power supplies do go bad for no apparent reason other than age.
Oso954 09-26-2012 02:59 PM
Fuses don't trip, they blow. Breakers trip. Not sure which ones you are talking about.
Surge protectors do not stop all surges. They are intended to stop massive surges like lightning strikes or dropping a 12kv line on a 120V line. They do nothing for other overvoltage conditions, unless that overvoltage exceeds their clamping voltage. Clamping voltage is generally over 300V.
