Pressure Switch Ratings - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2009, 07:43 PM   #1
DIY
Rewards Points: 150
Pressure switch ratings
I have become confused, as is common, about air compressor pressure switches and the ratings there on.
The pressure switch I have on my compressor is rated at 10 amps (it's an ordinary Square-D switch like we've all seen a million of). My compressor motor is rated at 15 amps, and does indeed draw 15 amps.
I'm helping my brother fix up an old compressor he got a good deal on, and it has a much larger motor on it, and what appears to be the mangled remains of the same style of switch that's on mine. What am I missing? How can these compressors be sold, or be safe, with motors drawing much more than the pressure switch is rated for?
gp_wa is offline   Reply With Quote
Old 08-24-2009, 08:56 PM   #2
Idiot Emeritus
Rewards Points: 1,492
If the switch has HP ratings stamped on it, go by these, not amps.
It'll have different HP ratings for different voltages and single or 3 phase. If the switch has two poles, both must be used, even if it's 120.
Rob
micromind is offline   Reply With Quote
Old 08-24-2009, 09:03 PM   #3
DIY
Rewards Points: 150
OK I follow that, but the same question applies.
My brother's compressor has a 10 HP motor on it, and even on 3-phase, the switch that's on it is rated for 5 HP or less. What??
Old 08-24-2009, 09:14 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
If it was 3 phase, the pressure switch would not start the motor directly, but pull in a starter for the motor.
Old 08-24-2009, 09:20 PM   #5
DIY
Rewards Points: 150
Ah, that may explain it then, this compressor used to be 3-phase before the motor was swapped to a single phase unit. I guess the swap was more involved than I had assumed. Thanks
Old 08-31-2009, 10:12 PM   #6
DIY
Rewards Points: 150
Aaaand, we're back to it.
This compressor turned out to have a 7.5 HP, 33 amp 240 volt motor on it. A contactor has been acquired that is rated for 7.5 HP. I thought this would be simple, but as usual, I'm not so sure anymore
I whipped up a diagram in Paint. Is the 240 volt diagram any good? It occurs to me that we'd be protecting the circuit through the pressure switch with a 40 amp breaker. That seems wrong to me.
Note that I omitted grounding for simplicity. It's not actually going to be left out, so no yelling is required
[IMG]www.nwlink.com/~glenebob/compressor_wiring.gif[/IMG]
Old 08-31-2009, 10:43 PM   #7
Idiot Emeritus
Either one of your drawings will work.
The top one will need a contactor that has a 240 volt coil. It's code-legal (and common practice) to use smaller wire on a control circuit. #14 control wire is code-compliant for up to a 45 amp breaker.
The bottom one will need a contactor that has a 120 volt coil. The wire size will be based on the breaker supplying the control circuit. (#14 for 15 amp, #12 for 20 amp). The neutral must be either white or gray.
If I were installing it, I would use the top drawing. If there's more than one source of power in a control box, there's a much greater chance of getting shocked or blowing something up.
Rob
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Pressure switch stuck open? 2 areas im looking @ 1001miles HVAC 42 12-03-2012 04:51 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Pressure switch issue? or something else... rp4985 Plumbing 8 07-11-2009 03:31 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
