-   -   Prescolite exit sign (http://www.diychatroom.com/f18/prescolite-exit-sign-178753/)
RWolff 05-04-2013 04:00 PM
I have a prestolite illuminated exit sign for my gallery building which has a battery charge circuit and a 120v input.
I am replacing the two broken 2 pin G23 base CFL bulbs in it with new ones, the thing is the battery is gone, so there would be no battery backup light.
I tried to find out if having the battery backup is even required in Iowa, or for a business only open one day a week in the summer during the daylight afternoon hours, but I didn't find much of anything of any use.
Seems silly to have a backup light in it when it's over a glass entrance door with huge glass windows above and all around the door facing the sunlit street.
It does not have the flood light bulbs I've seen in basements and dark hallways, it just illuminates the red cutout "EXIT" on the unit itself. I can see needing it in a basement, dark hallway or back room though, but it doesn't look like the battery has been in it for a long time if ever, I assume it was bad and removed, or more likely never installed.
Anyone know for sure if it's required to have the battery backup in it functional?
If so I guess I can get a battery for it, if not then I won't bother with another system that has to be checked and maintained by putting a battery back in.
jbfan 05-04-2013 04:04 PM
Can't speak for where you are, but exit lights and emergency lights require a 90 minute light time when power goes out, or it has to be connected to the generator circuit.
Jim Port 05-04-2013 05:11 PM
Check with your Fire Marshal.
RWolff 05-04-2013 05:35 PM
The unit has a label that states it is rated for a 1.5 hour battery lighting time, so the unit itself meets that and the battery required appears to run around $12 to replace, so Iguess I'll just stick a new battery in the thing and be done with it.
mpoulton 05-04-2013 11:48 PM
Exit signs require illumination independent of building power* in every jurisdiction I am aware of. The point is for the sign to remain lit if there is a fire or other emergency which kills the room lights. Natural light cannot be relied upon - while you might only plan to be open during the day, you could change your hours at any time and the building has to be safe night and day.
* - emergency power systems may be an exception.
