Preparing For Inspection - I Pulled The Permit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 02:43 PM   #1
Question
Preparing for Inspection - I pulled the permit
Hello,
I pulled the electrical permit to remodel my home -- Repair some damage to bed/bath areas of the home and upgrade the kitchen. So, I've completed most of the work and now wonder if I have done more than I should have at this point in the process, so maybe you all that have been through this can tell me. I am getting building and electrical inspections
I understand that there will be 2 inspections: the first electrical inspection will be to check the wiring that I have done (before the sheetrock is put back up) and the 2nd electrical will be once everything is completely done.
So, here are my questions for preparing for the initial electrical inspection:
1) For the ceiling fixtures that I put up, can those already be wired in, or do I have to leave the wires unconnected and hanging out of the ceiling by the fixture?
2) Do I schedule the building (framing) inspection before the electrical inspection or after (I thought they said to call for the electrical first).
3) Wires connecting to receptacles/swithces - my understanding is that the outer plastic sheathing is to be off (last few inches) but that the black/white/ground/etc should not be connected to the switch/receptacle - is that correct (next qustion is related)
4) If I mistakenly had already connected receptacles/switches, when I remove the receptacles/switches to prepare for inspection (see question 3) , do I have to use a wire nut now to cap off the ends of my white/black/ground/etc wires?
5) any other advice?
Thanks,
DIYer
diy2morrow is offline   Reply With Quote
Old 08-17-2011, 03:08 PM   #2
Rewards Points: 6,652
What did your local code office tell you when you picked up their packet after applying for the permit?
Old 08-17-2011, 03:57 PM   #3
they were not too helpful. The attitude was: you passed the exam, you should know. My posted questions indicate what I believed to be the answer if I sort of had one.
Old 08-17-2011, 03:58 PM   #4
Master Electrician
Rewards Points: 3,746
The order of inspections really doesn't matter as long as they are done BEFORE insulation and drywall covers everything up. Devices and fixtures go in after drywall and painting.
brric is online now   Reply With Quote
Old 08-17-2011, 04:14 PM   #5
Code05's Avatar
Rewards Points: 1,104
Originally Posted by diy2morrow View Post
Hello,
Fixtures should not have been installed, use pigtail light sockets.
You should not install wires before framing unless you are sure that you will pass.
Strip and make up all grounds.
All electric has to be made safe before inspection. If circuit is dead you do not need wirenuts.
Make up all you boxes, trim out will much easier. Mark all necessary wires, switch legs, travelers, GFFI feeds...etc
Thanks,
DIYer
Good luck on your project.
Code05 is offline   Reply With Quote
Tags
inspection prepare
DIY Electrical. Permit, Inspection, Liability Concerns Stemboat Electrical 13 08-01-2010 05:21 PM
Basement ceiling height & Permit troubles mayo302 Building & Construction 5 06-04-2010 10:21 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
No Permit for my Porch and Deck jokiddjr Building & Construction 15 06-13-2007 11:34 AM
Permit not pulled for add'l Sqr Footage Colorado mrbizee Building & Construction 9 11-18-2006 10:59 PM
