Preferred Wiring Method - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 07:44 AM   #1
langless28's Avatar
Rewards Points: 152
preferred wiring method
Sorry for the crude drawing. I would like to know how the pros would go about wiring this? I know CODE is black and white but I think that wiring methods are a grey area and go along with many years of doing this sort of stuff and finding out what is easier/more efficient. Would anyone prefer one way or the other? Or is either way perfectly fine? The only thing I can see is that method #2 would put more wiring in the light boxes as opposed to #1.
langless28 is offline   Reply With Quote
Old 11-02-2012, 08:07 AM   #2
langless28's Avatar
Rewards Points: 152
and even after verifying it looked right in preview post, its showing up wrong in the browser (no spaces) let me see if i can get a drawing done
Old 11-02-2012, 08:27 AM   #3
Keep in mind other people reading this do not know anything about what you are doing...
You mention black and white, but I see no reference to that in the diagram?
Then what is...
"S3"?
"L"?
And in general what are you wiring? Example: "I am wiring 3 ceiling light fixture boxes and one switch." or "I am wiring 3 ceiling light fixture boxes to two 3-way switches".
Billy_Bob is offline   Reply With Quote
Old 11-02-2012, 09:03 AM   #4
Rewards Points: 2,516
Originally Posted by langless28 View Post
*===============================S3 (power here too)
* L------------L L
* /L L-------------L
* /L
* S3
-or-
* L------------L----------- L
* /L L L
* /L
* S3
Are you kidding?? Do you expect most on this forum to know Egyptian hieroglyphics?
Most computers have microsoft paint.. use that to draw simple diagrams:
hammerlane is offline   Reply With Quote
Old 11-02-2012, 09:10 AM   #5
langless28's Avatar
Rewards Points: 152
yes i realize that looks bad, i assure you it looked ok in the preview window. anyway here is a picture of what i want to do, which wiring method is best practice? S3 is a 3way dimmer switch and the R is recessed lighting.
Old 11-02-2012, 09:51 AM   #6
Several different ways to look at this (in general)...
Cost of wire: If you are a contractor building 50 homes, then using less wire on each home could add up to a lot of money in savings. So in that case, the method which would use the least amount of wire.
Then "box fill": There is a limit to the number of wires you can have in a certain size electrical box or light fixture electrical box. This is called "box fill".
Troubleshooting in the future: It is most common for wires to go from one fixture to the next like your second drawing. So if two fixtures were not working, it would be a good guess that there was a problem at the first non-working fixture or the last working fixture. So easier to troubleshoot (although a good electrician with good testing tools can troubleshoot anything.)
Fighting the wires / packing into box: Easier to cram 2 romex wires into a box than 3!
Old 11-02-2012, 09:52 AM   #7
Rewards Points: 3,130
I'm not sure there's a "preferred" way to wire this. Either will work.
Old 11-02-2012, 09:52 AM   #8
still does not help much...here is how your post showed up:
Old 11-02-2012, 10:15 AM   #9
langless28's Avatar
Rewards Points: 152
thanks billy bob, i did check with the halo electrical boxes beforehand, i can have a max of 3x #12 wires in there. you brought up some good points about trouble shooting. hammerlane, it appears to be working for other people.
Old 11-02-2012, 10:30 AM   #10
its working now for me...nice diagram by the way. Doesnt seem to be much difference other than box fill for the last four lites in the run. As mentioned prior, both will work. Flip a coin and decide.
Old 11-02-2012, 11:46 AM   #11
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Are you going to have a light over the sink?
Are you going to have undercabinet lights?
Bring the power into the far switch, feed the second switch with the 3 wire, then run the switch leg to the first can, and then each can forward.
I try to never have 3 cables in any can light.
Old 11-02-2012, 12:51 PM   #12
langless28's Avatar
Rewards Points: 152
yes under cabinet lighting (not in picture) power will go to the top right (of picture) switch. there will be a j-box under the floor (unfinished basement) to feed the pot lights, under cabinet, and two exterior lights off the lighting circuit.
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 10:00 AM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 12:17 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 08:49 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
