Preferred Outlet Box Type & Work Order - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-06-2008, 11:03 PM   #16
Originally Posted by thekctermite View Post
Just to be clear...
14ga wire is not "code" across the board in your area, or any area for that matter. The national electric code does not permit 14ga wiring for everything in a home. Specifically, your kitchen receptacles must be 20 amps and therefore must be fed with 12ga.
Although many people advocate it, there is not a requirement for 12ga wiring/20 amp circuits on general use receptacle circuits in bedrooms, living rooms, etc.
15 amp breakers....14 gauge wire
20 amp breakers....12 gauge wire
Your switches and receptacles are not "sized" for 14 gauge wire and not 12. If you're using the stabs in the back of the receptacles/switches, then 12 may not fit....But using the stabs is a crumby practice in many peoples' opinion (including mine).
hey, kctermite, can you help me?
Bluefire is offline   Reply With Quote
Old 12-07-2008, 02:51 PM   #17
DIYer
Start a new thread.
Gigs is offline   Reply With Quote
Old 12-07-2008, 02:54 PM   #18
Please start a new thread and we can help.
rgsgww is offline   Reply With Quote
Tags
electrical outlet box
Outlet not working? Madnpc Electrical 3 12-07-2007 05:51 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
DIYers and Professionals Can Work Together. WilbUild Building & Construction 5 04-08-2007 01:43 PM
outdoor outlets don't work. dbrew Electrical 2 12-03-2006 09:50 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
