-   -   Powered outlet on table saw outfeed table? (http://www.diychatroom.com/f18/powered-outlet-table-saw-outfeed-table-68829/)
b_corwin 04-11-2010 05:49 PM
Hi,
So I got a new table saw. It runs off a standard 15 amp circuit. I then built an outfeed table for it. What I would like to do is have a powered outlet on the outfeed table that I can use to plug in the saw.
My idea had been to simply get a 20 amp extension cord, cut the end, run it into a two gang box to a switch, and then jump from that switch to an outlet in the second slot in the box and then mount this box to my table.
Now, this is what I had hoped to do. I recognize there may be some questionable things in this plan so I turn to you all for advice as to what parts of my above plane are terrible.
Thanks for all advice.
Brian
andrew79 04-11-2010 08:40 PM
There may or may not be 100 different reason as per code why this isn't acceptable. I've never really looked into what the rules are on rigging something like this up being as it's not part of the house wiring but altering a device's wiring. I know exactly what your trying to do though. You'll leave your saw on at all times and use the installed switch to turn the saw on and off correct? I would use an approved switch for the saw motors rated HP(special switches for motors)so it'll handle getting turned on and off better. My grandfather used a setup in his woodshop with just a standard SP switch and had to replace it fairly often as it would wear out. Another idea would be to bypass the plug all together and just hard wire the saw to the motor switch...either or. Any places where the wiring will be subject to any abuse i would use Armoured cable(with ground).
b_corwin 04-11-2010 09:22 PM
well sort of
well im not really intending to leave the saw on at all times and use it as the main switch. I just want to have the outlet on the table so that i can have access to power there for things such as air compressors in addition to the saw itself. So i guess im not as worried about the life of the switch as it wont be used as the sole switch on the saw.
I am pretty sure I have seen stuff like this done many times. Perhaps I can use some sort of a glanded entry into a box.
B
andrew79 04-11-2010 09:27 PM
B
sure....i don't see why not. Use a utility box that's rated for surface use and go to town :).
Yoyizit 04-11-2010 09:38 PM
Use a GFCI for this extra outlet?
Fuse the line separately with a 15A fuse?
Use abrasion-resistant cord?
I'd think you'll still be safe if you don't do any of these.
Worry more about the blade and its guard. Hand surgeons charge between one and four kilobucks per hour.
AllanJ 04-11-2010 09:41 PM
You are not altering any devices other than an extension cord, namely cutting the receptacle end off of it and connecting up something of your choice (a junction box).
You can buy power strip extension cords that have a switch to control their receptacles so you don't need to alter anything, just mount the power strip receptacle block to your table.
Scuba_Dave 04-11-2010 09:42 PM
I've seen a setup like this online somewhere before
They pretty much did what you stated
Are you saying the switch will control both plugs on the outlet ?
You might want one live all the time
I always have a radio around...or a light..or something
andrew79 04-11-2010 09:51 PM
doing reno with no music is just not normal :laughing:
hayewe farm 04-11-2010 11:18 PM
One thing I would suggest is to use a compression fitting on the box rather than a BX connector to secure the cord and use 2 switch/receptacle units so you still have 2 outlets each controlled by it's own switch. I would also recommend you make your own shop extension cord using SO cord.
nap 04-11-2010 11:50 PM
Originally Posted by hayewe farm (Post 427415)
One thing I would suggest is to use a compression fitting on the box rather than a BX connector to secure the cord .
I think I understand the justification for this and if it's to keep the sawdust out, I would also suggest a bell box with weatherproof recep covers to prevent the sawdust from entering there as well. You can also get a weatherproof switch cover so you prevent sawdust from entering the switch as well.
just let me at this thing. I can easily turn a $20 project into a $200 project in no time flat.:laughing:
b_corwin 04-12-2010 09:48 AM
Thanks everyone,
I was pretty sure I had seen this type of setup before, but the wife wasnt so sure it was a sound plan.
I think I may just find a 3 gang box and have two outlets and a switch one outlet always on and one outlet switched.
Thanks,
B
b_corwin 04-12-2010 06:23 PM
Hey all
here is what I ended up with. Don't have the extension cord yet but this will be mounted off the side of the outfeed table.
just a four gang box with a hole drilled in one slot to take a nm cable clamp and two outlets and a switch.
http://www.flickr.com/photos/49238070@N03/4515749869/
