Powered Home Theater Furniture - How Do I? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 02:39 PM   #1
Powered Home Theater Furniture - How do I?
So I'm building a home theater cabinet. I'd like to have outlets in each of the component sections that run to an attached surge protector. What is the right way to do this? I'd ideally like for it to not catch on fire
In addition, I would like to run some fans on the backs of the component areas, they will all be powered off a 12V circuit. Can I integrate everything together and just do a voltage change to the fans? Should I have two completely separate circuits?
Thanks so much for any help.
wylker is offline   Reply With Quote
Old 08-16-2010, 03:19 PM   #2
Electrician
Proby's Avatar
Is your surge suppressor hardwired or cord&plug?
Why not just use 120Volt fans?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-17-2010, 09:25 AM   #3
I was planning to use a plug + cord suppressor, unless someone has a good hardwired recommendation that isn't too expensive. I'm using the 12V fans because I already have them...
Old 08-17-2010, 09:38 AM   #4
Rewards Points: 1,542
I do not see a problem with a cabinet or equipment rack (with or without wheels) with junction boxes on the back, receptacles for the video equipment and cord/plug to connect to a surge protector back there.
Add a transformer or an AC to DC power pack for the fans. This can be a doorbell style attached to and hard wired to a junction box, or could be a model train style with cord/plug. Just be sure the voltage is correct and the amperage is sufficient.
Home Theater Installation Help Please.... Read Me scott&halee' Electrical 4 07-18-2009 09:14 AM
home theater marquee larsarz333 Home Theater 1 06-03-2008 07:44 PM
Home theater system set up cannouu Electrical 11 04-15-2008 07:39 AM
home theater setup cannouu Electrical 5 04-09-2008 06:01 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
