Power Woodshop Breaker Panel From 30A Generator Output - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 06:47 PM   #1
Question
Power woodshop breaker panel from 30A generator output
OK, first off I'm not an electrician but am looking to DIY a power solution for my wood shop which is about 90' from my outside power panel to the house.
I have a generator with a 30A output which I think is more than enough to run the equipment I now have with plug and disconnect as needed to the devices. I have purchased a 90A indoor panel and a 30A Generator Input for the outside connection to the generator. I will drive a ground rod near the generator input outlet if needed.
I don't want to run the shed off of the house power as a sub panel.
Is what I'm planning on doing safe and are there any recommendations?
CD
93shopmonkey is offline   Reply With Quote
Old 08-02-2012, 06:53 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
The generator most likely already contains a Neutral / Ground bond, so make sure you keep the grounds and neutrals separate in the panel, other than that, you are good to go...
Old 08-02-2012, 06:57 PM   #3
Question on grounds
The input is a four wire with a built in ground and my feed also is a four wire. Should I remove the ground built in and tie in the power ground and then ground the generator off of the ground lug on it?
Old 08-02-2012, 06:58 PM   #4
Rewards Points: 13,446
That's going to get old real quick having to hear that generator running every time you use that shed, and gas is not cheap.
Old 08-02-2012, 07:02 PM   #5
E2 Electrician
Stop thinking..
You are supplying four conductors from the generator to the sub-panel, keep the grounds and neutrals separate in the sub-panel.
The Following User Says Thank You to stickboy1375 For This Useful Post:
93shopmonkey (08-02-2012)
Old 08-02-2012, 07:03 PM   #6
It actually quite quiet and will run over 12 hours straight on 5 gals of gas. I'd like a solar/wind solution but cost is prohibitive. Its a now solution until I can afford to pay someone to tie it in later to the main feed or to the water pump power connection out back if that's possible.
Old 08-02-2012, 07:05 PM   #7
This is good advice. Listen to it. Driving a gorunding rod in this situation is a huge waste of time and money.
Auger01 is offline   Reply With Quote
Old 08-02-2012, 07:06 PM   #8
FWIW, just because the generator has a 30A receptacle, it doesn't mean that it could supply that much current.
Calc is offline   Reply With Quote
Old 08-02-2012, 07:08 PM   #9
E2 Electrician
He'll figure out what he can and cant run on it.
Tags
breaker panel , generator , input port , woodshop
breaker panel Ehren51 Electrical 3 01-20-2015 05:23 PM
Proper placement for breaker panel in laundry room rrolleston Electrical 6 02-13-2012 10:34 PM
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 09:50 AM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
