Power Vent Water Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2013, 03:21 PM   #1
I am wanting to change out my old water heater and replace it with a new Power vent water heater. I just have one question is it good to run a 14/2 wire with a 15amp breaker with a GFCI or is better to run a 12/2 wire with a 20amp breaker with a GFCI. Thanks in advance for any help or input.
POWER STROKE is offline   Reply With Quote
Old 03-19-2013, 03:25 PM   #2
MarginallyQualified
Rewards Points: 2,464
Will you be able to make hot water when the power is off?
Old 03-19-2013, 03:54 PM   #3
Rewards Points: 980
In general I like to run 12/2 so you have it if you ever need it.
My water heater is only 2a (iirc) so it doesn't matter what breaker you used with it.
Why do you want a GFCI? Mine isn't, and unless there is a new code requirement I don't know about, I would say it is highly undesirable.
Toller is offline   Reply With Quote
Old 03-19-2013, 03:57 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Toller View Post
I
I would ask how the unit is wired and the location of the unit before saying it is undesirable. If it is a cord and plug unit and located in a unfinished basement, then it would be VERY desirable.
Old 03-19-2013, 06:13 PM   #5
Rewards Points: 980
Why? Doesn't seem particularly dangerous (especially since no one ever touches a water heater) and I'd rather not have my water heater go off because of a flakey GFCI.
Old 03-19-2013, 06:13 PM   #6
E2 Electrician
GFCI's are not flakey, and its code for a reason. If you dont understand the code then I suggest not answering in a manner that bypasses important code requirements.
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
allendk (03-21-2013), COLDIRON (03-21-2013), Jim Port (03-19-2013)
Old 03-19-2013, 06:16 PM   #7
E2 Electrician
I dont even know how to respond to " no one ever touches a water heater"
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 03-19-2013, 06:49 PM   #8
Licensed electrician
Rewards Points: 1,622
If the receptacle is in an unfinished basement it would require GFI protection.
Old 03-19-2013, 07:23 PM   #9
Yea it's a new code that passed in 2008 all basement and garage receps have to be GFCI
Old 03-19-2013, 07:35 PM   #10
Rewards Points: 980
I specifically said unless it was a new code requirement, and someone pointed out it was new in 2008.
And sure, they are flakey.
I can go a year without touching my waterheater, and floor lamp that I touch several times a day has a much higher potential for being dangerous on a ground fault then a water heater. So it is rather hard to see them as dangerous.
If you don't know how to read then I suggest not answering in any manner.
Old 03-19-2013, 08:00 PM   #11
I would hard say GFI's are flakey. They have proven to be reliable for many years.
Old 03-19-2013, 08:07 PM   #12
Rewards Points: 196
Isn't the copper piping connected to the water heater,also connected to grounds and neutrals,which in turn is connected to the floor lamp that is touched every day?
HVACTECH96 is offline   Reply With Quote
Old 03-20-2013, 06:33 AM   #13
Prior to the change there were a few exceptions for stuff like alarm panels and equipment plugged into single receptacles and ones in a dedicated space like behind a freezer. Otherwise unfinished basement receptacles have needed GFI protection before 2008.
Old 03-20-2013, 06:43 AM   #14
Electrical Contractor
kbsparky's Avatar
They certainly can be flaky. Try testing `em after a bad lightning storm has blown through.
We get more bad GFI reports after such events.
-KB
Old 03-20-2013, 08:24 AM   #15
Lord of Slums
Rewards Points: 1,974
Is a gas water heater with power vent considered a water source, requiring a gfi?
mj12 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Installing a vent for my water heater... Toller Plumbing 13 03-13-2013 10:25 AM
Why can't a water heater vent be extended? Toller Plumbing 6 02-21-2013 08:26 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
