-   -   Power Vent Water Heater (http://www.diychatroom.com/f18/power-vent-water-heater-174963/)
POWER STROKE 03-19-2013 03:21 PM
I am wanting to change out my old water heater and replace it with a new Power vent water heater. I just have one question is it good to run a 14/2 wire with a 15amp breaker with a GFCI or is better to run a 12/2 wire with a 20amp breaker with a GFCI. Thanks in advance for any help or input.
TarheelTerp 03-19-2013 03:25 PM
Will you be able to make hot water when the power is off?
Toller 03-19-2013 03:54 PM
In general I like to run 12/2 so you have it if you ever need it.
My water heater is only 2a (iirc) so it doesn't matter what breaker you used with it.
Why do you want a GFCI? Mine isn't, and unless there is a new code requirement I don't know about, I would say it is highly undesirable.
stickboy1375 03-19-2013 03:57 PM
12 Attachment(s)
Originally Posted by Toller (Post 1140955)
I
I would ask how the unit is wired and the location of the unit before saying it is undesirable. If it is a cord and plug unit and located in a unfinished basement, then it would be VERY desirable.
Toller 03-19-2013 06:13 PM
Why? Doesn't seem particularly dangerous (especially since no one ever touches a water heater) and I'd rather not have my water heater go off because of a flakey GFCI.
stickboy1375 03-19-2013 06:13 PM
12 Attachment(s)
GFCI's are not flakey, and its code for a reason. If you dont understand the code then I suggest not answering in a manner that bypasses important code requirements.
stickboy1375 03-19-2013 06:16 PM
12 Attachment(s)
I dont even know how to respond to " no one ever touches a water heater"
Jim Port 03-19-2013 06:49 PM
If the receptacle is in an unfinished basement it would require GFI protection.
POWER STROKE 03-19-2013 07:23 PM
Yea it's a new code that passed in 2008 all basement and garage receps have to be GFCI
Toller 03-19-2013 07:35 PM
I specifically said unless it was a new code requirement, and someone pointed out it was new in 2008.
And sure, they are flakey.
I can go a year without touching my waterheater, and floor lamp that I touch several times a day has a much higher potential for being dangerous on a ground fault then a water heater. So it is rather hard to see them as dangerous.
If you don't know how to read then I suggest not answering in any manner.
Jim Port 03-19-2013 08:00 PM
I would hard say GFI's are flakey. They have proven to be reliable for many years.
HVACTECH96 03-19-2013 08:07 PM
Isn't the copper piping connected to the water heater,also connected to grounds and neutrals,which in turn is connected to the floor lamp that is touched every day?
Jim Port 03-20-2013 06:33 AM
Prior to the change there were a few exceptions for stuff like alarm panels and equipment plugged into single receptacles and ones in a dedicated space like behind a freezer. Otherwise unfinished basement receptacles have needed GFI protection before 2008.
kbsparky 03-20-2013 06:43 AM
They certainly can be flaky. Try testing `em after a bad lightning storm has blown through.
We get more bad GFI reports after such events.
mj12 03-20-2013 08:24 AM
Is a gas water heater with power vent considered a water source, requiring a gfi?
