Power Transmission (Ranch / Farm) - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 08:51 PM   #16
Advice worth 2 cents!
Rewards Points: 150
Wait a sec...this discussion is missing a few details.
First, what kind of line is close to the property? Is it a transmission line or a distribution line? what is the voltage? (very important). what is the exact distance?
CDH is on the right track, get in touch with your local utility and get more details on the installation.
Anything close to 1 mile is NOTa DIY job. But, an experienced line contractor might do the job for a residential homeowner for a reasonable price.
Utilities can be touchy about these kinds of installations. There pretty stiff about the kinds on materials used and the condition there in. A good contractor will know the whole story.
Keep shopping around in your location, check with neighbors, talk to the locals...
You cannot do this yourself! setting poles is a lot harder than it looks!!!!
_pete
---pete
HandyPete is offline   Reply With Quote
Old 08-09-2009, 09:59 PM   #17
Rewards Points: 2,350
_pete
While I tend to agree, most of the responses to this were not suggesting that the DIY line would tie into the utilities lines. The idea was that the utility would drop a 120/240 line to a meter nearest their distribution, the the homeowner would take that 240 up to 4160 through his own transformer, and distribute it the mile to his house, then back down to 120/240.
I agree that most DIY'rs couldn't safely do this.
Old 08-09-2009, 10:00 PM   #18
WFO
Originally Posted by NCC-1701 View Post
I've always looked at it like 240V would do me in so 2400 or 4160 wouldn't make me more dead. Granted the margin or error is even smaller and should be given it's due weight. I hadn't thought of the lightening so I realize I have a lot more investigating to do.
K.
Dead is an absolute, so if that's the only worry, go for it.
If having a limb burned off or dieing slowly from your internal organs rotting away after being cooked or learning to use a prosthetic arm, foot, leg (you name it) or having skin grafts sounds like a drag...please reconsider. These types of injuries at high voltage are much more common than fatalities.
Another thing that nobody mentioned is....what is the Coop's policy on primary metering? Coop's will supply electricity at distribution voltage levels (usuallly to industrial concerns) but they also usually have a billing tariff that has a hefty minimum monthly bill. You might be jumping out of the frying pan into the fire. And, as mentioned, all the maintenance is yours.
Solar (last I heard) was running around $7 a watt.....much cheaper to get the line put in.
WFO is offline   Reply With Quote
Old 08-09-2009, 10:54 PM   #19
CDH
Rewards Points: 29
As stated earlier setting poles and stringing wire ie doing linework aint easy, if it was everybody would be doing there own, and I believe the original poster showed a transmission line in his drawing ie high voltage 69kv,138kv,230kv,500kv,750kv not distribution voltages ie 4160,12,470,14,400 and they are not going to let him tap off transmission line, that kind of voltage is stepped down at substations through step down transformers and sent back out on distribution feeders. I am a journeyman lineman and have been working on line crews for almost 25 years and I have seen some places that would let people build there own line as long as it meets their specs, but it is still not a job for the homeowner but as I stated in my earlier post he could probably get a local line contractor to build it cheaper than the co-op if they will allow it.
CDH is offline   Reply With Quote
Old 08-10-2009, 11:16 AM   #20
So I guess the elec. chair works at only 2400 vac because you're strapped into it and the current stays on for a while and the current goes through your head and they don't wish to merely wound you.
Old 08-10-2009, 04:25 PM   #21
Rewards Points: 1,500
The OP said he already had a 120/240 volt service (200 amps) near the power line. Whatever high voltage equipment -- neon signs, electric fences, a 4160 volt line to his house a mile away, cathode ray tube TV test equipment, etc. -- hung off the 120/240 volt service is up to him. For $52,000. the power co. would presumably run a line at distribution voltage (whatever fed the transformer that in turn provides his 120/240 service) the extra lateral mile to his home site and put a transformer and 120/240 volt service there.
AllanJ is online now   Reply With Quote
Old 08-11-2009, 06:28 PM   #22
WFO
If you've ever seen the movie "The Green Mile" with Tom Hanks, the scene where they have a botched execution is similar, though dramatized, to the actual first poor sap that ever got the chair (by all accounts). I heard that it took several tries to get him dead.
As I'm sure you know, it was Edison who promoted the AC electric chair (in his infamous AC vs DC battle with George Westinghouse) as a form of execution for the very reason that it was so hideous.
Old 08-11-2009, 09:23 PM   #23
Yeah, Mr. Hanks has made some good movies. . .
I heard that Edison wanted to say people who got electrocuted were "Westinghoused."
Old 08-11-2009, 10:01 PM   #24
WFO
Bingo.
Now that Westinghouse has become ABB, you're still getting "Westinghoused" IMHO!!
Old 08-12-2009, 10:19 AM   #25
Thread continues spinning.
This, and other interesting details, I've read in a book about Tesla. Called simply "Tesla". Another interesting anecdote about Mr. Tesla's encounter with Thomas Edison, was when he (Tesla) was an immigrant just off the boat. He was looking for employment. Edison had an offer for him. "Repair the lights of Mr. Morgan's boat and I'll reward you well". When the job was done, T. Edison told him "You're not getting a Dime". "But you promised", said Tesla. "I really did", but tough!!! (Now more than ever) Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
Old 08-12-2009, 07:35 PM   #26
BTW, here's a tidbit on Mr. Edison
Additional Requirements for the Diagnosis of ADD/ADHD:
1. The symptoms must be to a degree that is "maladaptive and inconsistent with development level."
This part is highly subjective. Remember: Just because a behavior appears to be maladaptive, it doesn't necessarily mean a child actually has some sort of brain defect, as proved by Thomas Edison's remarkable career after being kicked out of school for his divergent thinking traits.
Another link opined that Tesla was autistic.
Old 08-12-2009, 07:39 PM   #27
Tesla was a genius, there can be no doubt, but it is Thomas Edison and his engineers that ushered us into the modern era. Was he wrong a couple of times about some stuff? Sure, but that doesn't detract from his accomplishments either.
Old 08-12-2009, 08:25 PM   #28
WFO
True, but I have a hard time overlooking electrocuting animals to discredit a rival. Genius doesn't equate to ethical.
By the way, his biggest gaff was overlooking the residue deposited on the glass of his first light bulbs and missing out on developing the vacuum tube.
Old 08-12-2009, 08:39 PM   #29
I heard Armstrong (FM radio inventor) was driven to suicide by the sociopath CEOs of yesteryear who stole his invention and harassed the daylights out of him, and his widow collected millions in court for their conduct.
Business as usual. . .
Old 08-12-2009, 08:50 PM   #30
Discussing the greats of the Electrical world.
Yes. It's not the most compassionate thing to do, but we know from other sources that he had something of a conscience. (Cheating someone out of his hard earned pay is surely not one of them). The success of Thomas A. Edison is not so much with his inventions, but with the perseverance that he had, to see them through the development stage. It's been said that he took (in some cases) other people's ideas and worked hard to bring them up to a practical level --without giving credit to the original inventor-- ! (Now more than ever) Don't Drink and Drive!!!
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
