Power Through Outlet To Two Single Pole Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2009, 12:36 AM   #1
Power through outlet to two single pole switches
As the title suggests I have my power feed coming into an outlet and need to run two single pole switches off of the one. One is for the closet light and the other is for the main room's lights. I am unsure of how to do this and open to suggestions. My idea would be to wire the outlet then pigtail the two switches together ultimately hooking them to the switch. What do you think??? Help!
aaronmoon is offline   Reply With Quote
Old 08-12-2009, 01:31 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Try this....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-12-2009, 08:29 AM   #3
Rewards Points: 1,548
Nitpicking.
If the incoming power cable to the original outlet box is 12 gauge and this is a 20 amp circuit then you will need to use 12 gauge wire for all the wiring you add as shown above.
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
No power to outlet Cheapmom Electrical 14 04-10-2009 02:29 PM
Can you place an electrical outlet inside pole wrap. luweee Electrical 9 03-16-2009 12:50 PM
Plugging power cord in a non-grounded outlet sil Electrical 4 10-18-2007 12:23 PM
