Power Through A 3-way - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2008, 11:09 AM   #1
Rewards Points: 256
Power through a 3-way, into an outlet
This is the diagram I'm using:
http://www.homeimprovementweb.com/in...ch-option3.htm
That is the set up I have, with the addition that beyond the second switch is an outlet. I need constant power through the 3-way to run the outlet but can't find it. Is this possible, or do I need another hot wire?
moneymgmt is offline   Reply With Quote
Old 03-02-2008, 11:25 AM   #2
member
leoacrh's Avatar
you need another hot wire and neutral wire
leoacrh is offline   Reply With Quote
Old 03-02-2008, 01:01 PM   #3
Rewards Points: 1,452
Run the new 14-2 cable, from the first switch where the power comes in, all the way to the new outlet box.
There's a good chance you will need a larger box at switch #1; 20 cubic inches to accommodate the new cable along with everything else, or 22 c.i. if the box has screw down cable clamps inside.
(Or get unswitched power from another more convenient location not related to your 3 way setup.)
Old 03-02-2008, 01:28 PM   #4
joed's Avatar
Rewards Points: 12,016
You can't do it. You don't have a neutral wire in the switch box.
Power inverter AndrewL Electrical 6 03-02-2008 02:43 PM
Help! Mystery power in complex 3-way! mnyman2003 Electrical 12 12-16-2007 02:10 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
