Power To Switch First - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-21-2008, 08:48 AM   #16
Rewards Points: 2,350
Originally Posted by CowboyAndy View Post
So, what is the general concensus... do the pros prefer to run power to the switch first or run on a switch loop?
In residential it is almost always to the switch first, because it saves from making all your taps in a light box overhead. Unless you are fishing a difficult wall where getting one cable down is hard enough let alone 2. then you might set a j box and make the tap there.
In commercial work, the 2-wire switch loop is very common.
InPhase277
Old 02-21-2008, 09:09 AM   #17
joed's Avatar
Rewards Points: 13,368
No. The white wire should be used to bring power to the switch. Switched power must come back from the switch on the red and black wires. That way you will always have a white wire and black or red wire for fixture connection.
Old 02-21-2008, 09:17 AM   #18
When is fishing season?
CowboyAndy's Avatar
InPhase277
Is there a reason why it is more common in commercial work?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 02-21-2008, 09:33 AM   #19
Mostly because the areas above the walls is accessible with tile ceilings and such. It is easy to drop a single cable to a switch box and another to a light from a j-box that already has the power conductors in it. And later on, when that space is used for something else, the box is accessible to be rewired.
InPhase277
Adding a Switch and jump power Bull-37 Electrical 9 01-10-2008 05:45 PM
Help! Mystery power in complex 3-way! mnyman2003 Electrical 12 12-16-2007 01:10 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Power disconnect switch lmanwarren Electrical 1 03-28-2006 03:17 AM
