Power Supply Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 03:20 PM   #1
I have an headphone amplifier that is missing a power supply, it requires 9 volt 750 mA ac, I have a 12 volt 830 mA ac power supply with the proper tip, will it work or is the 33% higher voltage, too high?
tyhorstman is offline   Reply With Quote
Old 11-04-2012, 05:25 PM   #2
Master Electrician
Rewards Points: 3,874
Originally Posted by tyhorstman View Post
I have an headphone amplifier that is missing a power supply, it requires 9 volt 750 mA ac, I have a 12 volt 830 mA ac power supply with the proper tip, will it work or is the 25% higher voltage, too high?
That's 33% higher,and 9 volts is 9 volts not 12 volts is 9 volts.
brric is online now   Reply With Quote
Old 11-04-2012, 05:48 PM   #3
Yeah, sorry about the 25 percent, brain fart. Are you saying it shouldn't be used at 12 volts?
Old 11-04-2012, 06:37 PM   #4
Missouri Bound's Avatar
It may work real good for a real short time!!
Go to Radio Shack, they aren't that expensive...get the right one.
Do you want it your way or the right way?
Old 11-04-2012, 06:38 PM   #5
Rewards Points: 3,256
It's impossible to say unless someone knows the product very well. As a general rule...don't push your luck unless you have better information.
As an example, we have a product that is listed for 9 volts but will operate just fine at 35 volts max. Another product is also listed at 9 volts but 12 volts would be pushing the limit.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
mpoulton (11-04-2012)
Old 11-04-2012, 06:38 PM   #6
Master Electrician
Not if it requires 9 volts.
Old 11-04-2012, 06:52 PM   #7
Yeah I didn't think I should use it but I thought I would ask. Thanks for the help I'll pick up a matching power supply at radio shack.
Old 11-04-2012, 09:01 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,938
My guess is that it would probably work, but I wouldn't risk it unless you just don't care about destroying it. Most types of amplifiers aren't too picky about input voltage. The input voltage determines output power (indirectly, by changing gain) so it would be louder and also produce more heat. It's unlikely that there's less than a 33% voltage overhead on the components in the amp, so 12V would probably not immediately damage it. However, many "12V" power supplies have actual output voltages that are more like 14-18V when unloaded. So you could be running almost double the nominal voltage, and that might be a problem.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 11-04-2012, 10:47 PM   #9
Yeah this particular power supply has a voltage output of about 14.5 volts unloaded.
charging scooter battery with switching power supply cynicalceleste Electrical 7 06-07-2011 07:54 AM
Tapping CPVC supply lines for new bathroom - question NEW-B Plumbing 0 05-12-2011 09:20 AM
changing the power supply robut PC Repairs & Upgrades 4 01-08-2011 01:29 PM
12V power supply failure alarm neildawes Electrical 7 08-02-2010 09:04 PM
Electric question from power pole to unit Slocalaman Electrical 3 11-06-2008 03:23 PM
