Old 04-09-2012, 09:01 PM   #1
Share |
Power Supply - Is Amperage Important?!?
Hi all,
Just wondering...I have a drum machine (Boss DR-3) that came via eBay without a power supply. I believe it requires a 9V 5A (500mA?) Output power supply. I have one hanging around the house that is 9V 6A. So it is 1A more than is specified for the equipment.
If I plug this in (the 9V 6A one), will it Blow it up?!? Fry it??
What could possibly happen?
Cheers...
FangIT is offline   Reply With Quote
Old 04-09-2012, 09:07 PM   #2
Licensed Electrician
k_buz's Avatar
The power supply is rated up to 6A. If your machine only needs 5A, you are fine.
Old 04-09-2012, 09:16 PM   #3
Thanks k_buz. Actually, I got it a bit wrong up in my original post. The specs for the drum machine states (9V) 'Max current output 0.5 amp'.
The 'spare' power supply I have is Output 9V - 0.6A.
So even if I had one with, say 2.0A Output, It would be OK?
(Thanks again!!)
Old 04-09-2012, 09:19 PM   #4
k_buz's Avatar
You should be fine.
The Following User Says Thank You to k_buz For This Useful Post:
FangIT (04-09-2012)
Old 04-09-2012, 09:44 PM   #5
Semi-Pro Electro-Geek
(Thanks again!!)
None of this adds up with your first post. Your first said the machine requires 5A (that's 5000mA, not 500). Now you say it says 0.5A (500mA), and before you said you had a 6A power supply, and now you're saying 0.6A or 2A.
Bottom line: You need a power supply with the SAME voltage rating at AT LEAST the same current rating as the device you're powering.
mpoulton is offline   Reply With Quote
Old 04-09-2012, 09:58 PM   #6
Thanks for posting mpoulton.
Yes, apologies. To clarify:
The Drum machine requires 9V & Max Current Output 0.5A (500mA)
I have two spare 9V adapters (power supplies):
One is: 9V - 0.6A (600mA)
The other is: 9V - 0.8A (800mA) 7.2VA (whatever VA is?)
I used 2.0A (2000mA) above purely as an example.
I think I am now clear that what ever I use, It must be exactly 9 Volts output and Minimum 0.5A (500mA) Output. So either of my spare ones will be OK to use.
Cheers & thanks all for your feedback!
Old 04-09-2012, 10:03 PM   #7
Learning Things Every Day
Jay 78's Avatar
I'd like to know what you think of the drum machine once you use it.
I'm in the market for one.
Under Construction
Jay 78 is offline   Reply With Quote
Old 04-09-2012, 10:12 PM   #8
Hi Jay 78,
So far so good...I've been using it with batteries but it's getting expensive!!
The Boss DR-3 is a good starting point although instructions are sketchy. Drum and Bass (guitar) sounds are good/excellent, although Bass could be louder - this might be adjustable?!?. I'm trying to re-create some classic drum tracks (e.g. Rolling Stones - Dead Flowers). Relatively easy so far and drums sound similar to original song.
All in all, bloody good fun once you get the hang of it and start to play some guitar over the top! An absolute waste of money if you don't have a few hours to read and experiment up front.
Cheers!
Old 04-09-2012, 10:16 PM   #9
joed's Avatar
In addition to the proper voltage and the minimum mp requirements you must also make sure yo have the proper type of power. You must have AC or DC volts as required.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 04-09-2012, 10:36 PM   #10
Thanks joed,...there's always something else!
the specs say:
Connectors>
DC IN (AC Adaptor Jack)
Power Supply>
DC9V: Dry Battery (R6/LR6 (AA) type) x 6, AC Adaptor (PSA-series)
The spare power adaptors:
One is an 'AC-AC Adaptor, Input 240V~50Hz'
The other doesn't state AC or DC, but has 'ITE Power Supply, Input 100-240V - 50/60Hz 0.3A' ? (this one has the rectified ac symbol on the output meaning it can be treated as dc, I think!).
Now totally confused!
Supply power to a garage in Ontario Canada StarGehzer Electrical 7 10-15-2010 12:47 PM
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 03:19 PM
Custom Power Supply: Help Please :| tigerpushpop Electrical 4 05-09-2009 09:02 AM
Connecting AC to a DC device kimbokasteniv Electrical 18 11-02-2008 08:11 AM
URGENT:problem with power supply to amplifiers mdhek001 Electrical 13 08-22-2007 04:35 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
