Power For A Sub-panel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 03:35 PM   #1
NAIL BENDER's Avatar
Question
Power for a sub-panel
If I want to put more than 60 amp into a sub-panel, how can it be done..?
I want to put a 100 amp sub in the shop and with a welder, air compressor and electric heaters I don't think a breaker in the main panel can provide what I need.
Help.
Danny aka: NAIL BENDER
NAIL BENDER is offline   Reply With Quote
Old 12-21-2011, 03:39 PM   #2
Rewards Points: 13,300
Depends on what size main panel you have, if there's 2, slots in the panel avalible.
Your also going to have to upgrade the wiring going to the shed.
Old 12-21-2011, 03:46 PM   #3
Hi Joe,
I've got 200 amp main box with room for about a dozen more breakers. Currently the shed has no power except for an extension cord from the house. A portable generator is powering the welder but now that it's cold outside and exhauste fumes can't get out past the closed door....
Old 12-21-2011, 03:50 PM   #4
Julius793's Avatar
I don't really understand the question, if there is space in the panel get a double poll 100a. Or are you asking how to install a sub?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-21-2011, 04:13 PM   #5
The largest double breaker I've seen was 60 amps.
A double 100 breaker would solve my problem.
I will have to do a google search for the BIG BREAKER...
Thanks for your help Julius, I appreciate it a bunch....!
Old 12-21-2011, 04:18 PM   #6
Electrical Contractor
kbsparky's Avatar
What brand of panel do you have?
The breakers larger than 60 Amps are more expensive -- and as a result -- are kept in a separate place in most home-horror stores.
You have to ask for `em.
-KB
Old 12-21-2011, 04:19 PM   #7
Julius793's Avatar
Try home depot they usually have
Old 12-21-2011, 08:03 PM   #8
This breaker box is on the power pole next to the house and feeds (under ground) a smaller panel in the kitchen.
It's a Cutler-Hammer model # BR2040B200R and other than the single 30 amp breaker I installed for an RV duplex outlet, the panel is vacant below the 200 amp main breaker.
Old 12-21-2011, 08:24 PM   #9
Electrician
SD515's Avatar
Rewards Points: 504
HD & Lowes, about $40
http://www.homedepot.com/Electrical-...&storeId=10051
http://www.lowes.com/pd_103015-82364...&storeId=10151
Kyle
Old 12-21-2011, 09:37 PM   #10
Thanks Kyle,
I saw HD had both a CH2100 and CH2100CS.
What's the difference.? and what does the 'CS' mean..??
Thanks for your help.
Old 12-21-2011, 10:35 PM   #11
Electrician
SD515's Avatar
Rewards Points: 504
You said you have a ‘BR’ panel. Eaton list a BR2100 (10kAIC) or a BRH2100 (22kAIC) that fits your panel. CH breakers are another one of their models they make. They don’t interchange.
CS=clamshell (packaging)
Kyle
Old 12-21-2011, 11:09 PM   #12
Originally Posted by SD515 View Post
You said you have a ĎBRí panel. Eaton list a BR2100 (10kAIC) or a BRH2100 (22kAIC) that fits your panel. CH breakers are another one of their models they make. They donít interchange.
Thanks again Kyle,
I do have a 'BR' panel and wasn't paying attention and focused only on the CS. That's why I joined this board, cuz life is tough on us with only 2 remaining braincells....
You saved me a bunch of money for gas running back & forth to HD's exchange dept.
Danny
Old 12-21-2011, 11:16 PM   #13
Electrician
SD515's Avatar
Rewards Points: 504
Lol. Jim Port would say I picked the wrong day to quit sniffing glue (inside joke…I’m sure he’ll see it).
Stick around, ask questions, and contribute. There are some excellent trades people and DIYers on this website.
Kyle
Old 12-22-2011, 11:42 AM   #14
OK, next redundant question:
After reading several threads I understand that feeding this sub-panel through buried PVC I will need individual wires (THWN or XHHW) of proper size and I was planning on grounding rods.
So is a ground wire from sub to main panel a must and without one is bonding the neutral in this sub still a definite NO NO...?
Danny
Old 12-22-2011, 12:15 PM   #15
Love for Construction
<*(((><'s Avatar
Bonding the neutral to the ground on any subpanel is a no-no. If the shed where the subpanel is located is detached from your house you will need to install a ground rod at the location.
You will still need 3 conductors and a ground going in between your main panel and your detached garage.
-luke-
<*(((>< is offline   Reply With Quote
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Single Phase Sub Panel from 3 Phase Power supply The Quan Electrical 1 10-30-2011 07:50 AM
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 06:39 AM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
