I was visiting my mother last week and tried a "Quick fix" hack for adding a receptacle that has me stumped.
This is a 100+ year old "Company House" (coal miner) that electricity was added sometime in the 1920's. Most of the house is 2 wire (no ground), but the fusebox was replaced with a circuit breaker panel at some point and a few grounded circuit were added. Most rooms only had two receptacles and a ceiling light.
My request was simple. Add some type of receptacle in a room for a power lift chair/recliner. I had no tools with me except for a neon circuit tester I found in my fathers old tools. The location was almost directly over the circuit breaker panel in the basement, but without tools (and 100 year old plaster that had been paneled over) I did not want to add a new circuit. I thought I'd just run an extension in the basement from a three wire circuit outlet that was 10 feet away. As far as I knew, that circuit only had two receptacles on it, both to washing machines, one in the basement that is no longer used and one upstairs.
The quick hack was buying a cheap power strip at Lowes. Cutting off the plug. Drilling a 3/8 hole in the flooring. Putting the cut power strip wire through the hole. Adding a grounded male plug to the power strip. Plugging the power strip into the receptacle using a 10' extension. I'm sure not to code, but seemed easy and only took about 15 minutes - but then
The power strip test light came on, but chair didn't work. The washing machine stopped working. Disconnect the power strip and the washing machine works. (in that configuration, the neon test lamp seemed dim). A drill plugged into the power strip would work on some plugs, but not on others.
Well after about three house of scratching my head and testing the best I could, I gave up and disconnected the hack. I checked the two known receptacles for correct wiring and made sure I didn't have a neutral crossed. I tested the chair on another circuit (using extension cord) and found that it was erratic. It is a transformer with two 9v batteries for emergency power. Sometimes it worked (up), but then would not go down until giggled things - never could find anything consistent. After wasting a bunch of time trying to figure it out, I just wrote if off as a bad transformer that would have to be tested and replaced by the dealer.
I though I'd leave in the power strip and at least she could have a lamp next to the chair when I ran into more things that confused me. I grabbed a little table light that had one of the little round CFL light in it and plugged it in. The light seemed a little dim, but got a little brighter. I tried another receptacle on the power strip and it didn't come on at all. I turned the power switch off and on and the light came on - a little brighter. Each receptacle closer to the switch would be a little brighter! That's when I gave up and said "Steve, your in over your head - something is wrong and you don't have tools to test it".
Any idea what could be wrong. Bad power strip? Something else on the circuit (faulty) that could cause this? I didn't mention that the the visit is 800 miles away so it is something I can't do anymore testing on until the next visit in the summer. (when I'll probably just have a new circuit added)
