Power On, Screen Off - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 11:20 AM   #1
Power on, Screen Off
I turn on the TV and it flickers red lights for about 10 seconds then stops, then I turn it on on again and it makes a noise, and the green power on indicator light turns on but the screen does not display anything, it stays blank. How can I fix this problem??
FlamesFanAddict is offline   Reply With Quote
Old 01-13-2012, 11:38 AM   #2
joed's Avatar
Rewards Points: 11,548
Call a repair person.
Not likely anyone here can help but if you give us a make and model maybe someone will able to assist you.
Old 01-13-2012, 12:16 PM   #3
Hardcore DIY'er
If its an LCD tv its most likely an issue with swollen/leaking capacitors on the control board. However its not really an "Home Improvement - Electrical" item, its more an electronics repair item. Ultimately though, I would say 80% of the failures in modern electronics are due to bad capacitors. You can dissassemble the component, identify the swollen/leaking capacitor and then order replacement ones and solder them in. This takes a little knowledge or research though. I order capacitors from digikey all the time to fix electronics. You have to match voltage amperage and style, then you need to know how to solder and make sure you put install with the correct polarity. Easier done than said.
EvilNCarnate is offline   Reply With Quote
Old 01-13-2012, 12:25 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Unless you know what you're doing, just take it to a repair shop.
Oh. And those capacitors can knock the heck out of you.
Sent from a Samsung Galaxy SII
titanoman is offline   Reply With Quote
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 03:54 PM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
Can I give 12V DC to power inverter through PC Power supply? inverter General DIY Discussions 3 07-06-2009 10:38 AM
