Power Run To Box Not Being Used - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 06:42 PM   #1
Power run to box not being used
I'm currently waiting on my inspector and have a bit of an issue and just wanted to make sure I was doing the right and safe thing.
I have an end-of-run switch box that has power coming in and WAS feeding a light. I took the power coming out off and ran a new 14-3 wire for a 3-way, and then ran 14-3 from the new fixture to a new switch location. I'm all set for the inspector, but I still have the power to that circuit turned off. I was wondering, can I just screw some wire nuts on the hot end, or electrical tape, or whatever, so that I can turn the circuit back on and get the rest of the receptacles on that circuit up and running until my inspector checks off the work and I can put the lighting and switches back in?
Any ideas/suggestions?
Thanks!!!
Shaotzu is offline   Reply With Quote
Old 05-16-2011, 07:24 PM   #2
joed's Avatar
Rewards Points: 13,358
Wire nuts should be fine.
The Following User Says Thank You to joed For This Useful Post:
Shaotzu (05-17-2011)
Outdoor Hot Tub / Overhead Power line issue scottwilliamson Electrical 3 02-12-2010 10:37 AM
Devices to save on phantom power fetzer85 Electrical 7 12-04-2009 08:03 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 07:45 PM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 12:16 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
