Power Receptacles Not Installing "square" - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 08:17 PM   #16
Tinkerer's Avatar
If I understand your post, it's not a "plumb issue" but a problem with the face of the receptacle not being flush, or parallel, to the wall, i.e. the left side of the receptacle is further into the box then the right or vice versa. If that's the case, then Michael Keaton is right. fold the wires in an "S" shape and work the outlet in. Don't try to muscle it in or you'll break something.
Tinkerer is offline   Reply With Quote
Old 12-08-2009, 08:34 PM   #17
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
and this is another reason to use stranded wire
I really feel sorry for all you guys that have to use solid, I really do.
Old 12-08-2009, 09:10 PM   #18
Rewards Points: 518
Still trying to figure that one out when most end devices (eg. almost all fixtures, some switches) are 18awg stranded.
n0c7 is offline   Reply With Quote
Old 12-08-2009, 09:55 PM   #19
nap
You talking to me?
nap's Avatar
Huh?
down here, most residential builds use NM which is solid and either 14 awg or 12 awg.
Not sure what you have happening up there in the wild white north lands.
Old 01-02-2010, 01:24 PM   #20
LeviDIY's Avatar
Rewards Points: 252
Pictures, finally
Happy new year.. sorry I've been so tardy with these pictures, but here they are...
I didn't to take off the cover plates, but you can sorta tell the GFCI outlets are "bent" towards the left (Could this be because I'm a southpaw? )
These are only the 2 most recent culprits, most of the standard outlets around the house that I've replaced this happened to, but I was able to bend them manually once screwed into the j-box to align CLOSE to correct... the GFCI's are just too big/bulky to do this...
Is this a symptom of too much wire in the box? I like some of the suggestions earlier.. its bugging me to no end, and usually this is the final step in putting the room back together and to have it not look great is a bummer...
LeviDIY is offline   Reply With Quote
Old 01-02-2010, 02:23 PM   #21
Tinkerer's Avatar
The suggestions made here will work, just remember that finesse is better than brute force & ignorance. Don't just try to jam the outlet in.
The problem with those particular outlets is that there is either wire or wire nuts bunched behind the outlet on the one side preventing it from sitting flush. As far as too much wire, hard to tell without seeing it. If there is too much wire bunched behind the receptacle, you can either re-position it to ease the installation or cut it shorter. Just be sure that cutting the wire won't cause a wire nut to be stuck behind the unit or you'll have the same problem.
Tags
receptacle , wiring
Blown fuses while changing switches & receptacles marc_easy Electrical 9 07-05-2009 10:24 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
