Power Receptacles Not Installing "square" - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 11:04 AM   #1
LeviDIY's Avatar
Rewards Points: 252
Power receptacles not installing "square"
I have a maddening ongoing issue as I work through repairs throughout my place and finish the kitchen remodel..
When it comes time to screw the receptacles back onto their brackets and put the cover plates on, they always seem "out of square." Like angled or tilted.. and for me always beinging in towards the box to the right.
I push in evenly and rock back and forth and screw evenly... but I always have to almost bend the metal screw brackets to make it flush.
Am I doing something wrong? Is this common? Any techniques to correct? (Do you need pictures of what I'm talking about?) It seems worse with GFCI than standard...
LeviDIY is offline   Reply With Quote
Old 12-08-2009, 11:56 AM   #2
Rewards Points: 518
I usually just eyeball it and got better over time but if you're really anal you could turn the breaker off and use a 4" level vertical butt up against the receptacle while you tighten it down.
n0c7 is offline   Reply With Quote
Old 12-08-2009, 12:53 PM   #3
300zx's Avatar
Post
I think a pic is in need so we can see what you are talking about. Are the boxes not flush.
300zx is offline   Reply With Quote
Old 12-08-2009, 01:11 PM   #4
LeviDIY's Avatar
Rewards Points: 252
I'll get a picture up tonight when I get home.. but yes, this is happening not on new construction, but replacing older receptacles.
Old 12-08-2009, 01:25 PM   #5
300zx's Avatar
Post
Ok,Hope a pic will help out can you take a pic of rec out of box so we can see whats going on Thanks.
Old 12-08-2009, 01:30 PM   #6
Jay123's Avatar
I think he's talking about the receptacle not being in plane with the wall...not plumb/level....are the top and bottom tabs of the receptable not catching the sheetrock?
They make extensions boxes if you need that much depth change...
http://www.google.com/products/catal...wAA#ps-sellers
Jay123 is offline   Reply With Quote
Old 12-08-2009, 01:43 PM   #7
300zx's Avatar
Post
If that is the case then i would use these Spark Guards alot cheaper
Old 12-08-2009, 01:51 PM   #8
Jay123's Avatar
can they be added to an existing box?
Old 12-08-2009, 01:52 PM   #9
Jay123's Avatar
looks like it slips right over it
Old 12-08-2009, 02:03 PM   #10
300zx's Avatar
yes,they slide over the rec also.But i don't know until op post pics to see what we are dealing with.
Old 12-08-2009, 07:29 PM   #11
Yes
Yes (for beginners)
Yes. Fold the wiring in an S shape behind the device. Push the device into place and square/flush it before puttin he screws in.
It takes some foreplay. You can't just jam it in there.
220/221 is offline   Reply With Quote
Old 12-08-2009, 07:32 PM   #12
Electrician
Rewards Points: 778
I like to put the screws in about halfway, then i push the plug in all the way, do any adjustments i need to and then put the screws all the way in.
darren is offline   Reply With Quote
Old 12-08-2009, 08:44 PM   #13
Thumbs up
That's the key. When the boxes are not flush. Especially on kitchen counters (backsplash) you will have problems aligning the cover and the receptacle will swing either way. But generally, it takes eye level to adjust them. The reason, GFCI receptacles are more difficult is because they are wider.
spark plug is offline   Reply With Quote
Old 12-08-2009, 08:59 PM   #14
Wink
I do it like 220/221 suggested. Another small detail that might make a difference. If the wire enters the box at the top, use the lower set of screws. And the top set of screws if it enters from the bottom. That would help slide the wires back instead of squeezing them. Second thing. Set the wires all the way back and "push" the receptacle back until flush BEFORE you fasten the screws to the box. (No matter what) Don't Drink and Drive, Ever!!!
Old 12-08-2009, 09:04 PM   #15
I always fold the wires back into the box 1st
Then pull them back out far enough to install the device
Tags
receptacle , wiring
Blown fuses while changing switches & receptacles marc_easy Electrical 9 07-05-2009 11:24 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
