Power Panel Missing, All Receptacles & Switches Removed - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2010, 02:06 AM   #1
power panel missing, all receptacles & switches removed
Foreclosure - 3k sq ft house, owner got even with the bank. removed all switches & outlets luckily they did not cut the wires off short.
Any words of wisdom / tips in putting things back together?
I will grab a wire tracing device & try to untangle this mess.
I've wired a couple houses before & have good electrical skills. Will be pulling a permit for the all in one meter panel box. They even pulled the condenser fan from rooftop air unit. All and all I did get a smoken good deal from the bank.
thanks for your thoughts.
shortsell is offline   Reply With Quote
Old 03-24-2010, 05:55 AM   #2
For the obvious, all #12 wires are 20amp, #14 are 15A. 20A will be for kitchen, bathroom, maybe a workshop. Bigger wire is for A/C, ranges/ovens. To find a circuit, short hot/neut together at an outlet then look for the short where the panel goes.
Old 03-24-2010, 10:12 AM   #3
Licensed electrician
Rewards Points: 1,892
A wire toner will probably help you figure out some of the wiring. It will be harder unless the splices are already made.
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
Power receptacles not installing "square" LeviDIY Electrical 20 01-02-2010 02:23 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
