Power Outlet Vs. Water Supply Position For Washer - Electrical - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 09:59 PM   #1
Rewards Points: 1,062
Question
power outlet vs. water supply position for washer
i was wondering if it's OK that a washer power outlet be immediately under the water valves, like maybe 18".
thanks
Old 10-21-2011, 10:03 PM   #2
Electrical Contractor
kbsparky's Avatar
I would not recommend doing that, but not sure if there is any Code violation ...
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
amakarevic (10-22-2011)
Old 10-22-2011, 08:00 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
No Code violation, but typically they are put at least one stud bay over.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water supply line blackhemi Plumbing 4 04-09-2011 09:18 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
No Hot Water Supply after Removing R.O. System EZ Gruv Plumbing 2 07-04-2010 11:22 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
