Power Outlet And Switch Standard Heights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-06-2008, 11:06 PM   #1
Rewards Points: 1,062
Question
power outlet and switch standard heights
i can't find it anywhere in my book - what are the standard heights for power outlets and switches above the floor, measured to the bottom of the receptacle ?
Old 09-06-2008, 11:34 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
The only place you will find anything is in the ADA requirements, which is irrelevant in the average home. Other than that there are NO set heights.
In new construction I use 48" TTT (top the top) of switches, kitchen & garage receptacles.
16" TTT of standard receptacles.
42"-44" TTT of bathroom GFI receptacles.
24" for a gas range receptacle.
30"-36" for washer/dryer receptacles (this is due to newer "European" design machines).
I use TTT because I hate having to bend down to line up the mark with the bottom of the box. This makes for a very inaccurate box placement.
On commercial jobs I follow the spec, which is typically to the center.
On existing jobs or renovations I simply match the other boxes on site.
Old 09-07-2008, 12:18 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
as petey was saying, there are no "standards" unless you consider the hammer handle that a lot of resi electrician seem to use to set recep height.
On the job I am currently, the light switches are 42 inches to center. Receps are 24 inches to center. I have worked jobs with the receps as low as 6 inches to center (what a pain trimming those were).
As long as you are consistant with your dimensions, most folks will nevre notice or care. If you are asked, you can make up whatever story or reasoning you want to tell them.
Old 09-08-2008, 10:05 AM   #4
Power Gen/RS Engineer
Rewards Points: 566
As Nap says, many people set the receptacle heights using their hammer handle as reference.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 09:08 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Outlet controlled by switch Shardi Electrical 4 10-09-2005 07:24 PM
