Power From Outlet To Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-09-2008, 11:56 AM   #1
power from outlet to switch
i have an outlet controlled by a switch. The power goes from outlet to switch. I want to maintain full power at the outlet and use the switch to control a new ceiling fan. What must I do?
lincoln85 is offline   Reply With Quote
Old 10-09-2008, 12:06 PM   #2
So the power comes in from the outlet? Is there a red wire attached to the outlet?
rgsgww is offline   Reply With Quote
Old 10-09-2008, 01:04 PM   #3
joed's Avatar
Rewards Points: 11,990
At the receptacle connect both black wires to the gold screws and connect both white wires to he silver screws. NOTE if the receptacle was only half switched then you need to replace the receptacle as the tab will be cut between the gold screws.
At the switch connect the white from the new light to the white from the switch. Connect the two black wires to the switch. The switch will now control the light at the end of your new cable.
power outlet and switch standard heights amakarevic Electrical 3 09-08-2008 10:05 AM
3 Way Switch Draw additional Power? mattyd Electrical 15 03-24-2008 02:36 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Outlet controlled by switch Shardi Electrical 4 10-09-2005 07:24 PM
