Power Outlet Right Under A Window - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 11:22 PM   #1
Rewards Points: 1,062
Question
power outlet right under a window
can a power outlet be right under a window? asking because of the possibility of window leaking.
thanks
Old 02-06-2012, 11:31 PM   #2
Rewards Points: 14,008
It's done all the time.
I do it so the lady can put there Christmas candles in the windows.
amakarevic (02-06-2012)
Old 02-06-2012, 11:46 PM   #3
cool, thanks
Old 02-07-2012, 06:41 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
amak....thanks for asking that question....I wanted to ask it as well.....for some reason I was thinking that you couldn't put outlets under windows.....
Old 02-07-2012, 07:23 AM   #5
Rewards Points: 506
I don't mean to sound harsh, but what does a potentially leaking window have to do with electrical installations. Think about it before responding.
jlmran is offline   Reply With Quote
Old 02-07-2012, 08:18 AM   #6
Rewards Points: 242
I had a leaking window and yes there is an outlet under it. Photo to prove it.
collegetry is offline   Reply With Quote
Old 02-07-2012, 01:17 PM   #7
MarginallyQualified
Rewards Points: 2,464
This is probably related to use of electric baseboard...
no outlets *above* the BB = none below that window.
The 6/12 rule still applies though.
Old 02-07-2012, 07:15 PM   #8
6/12?
The 6/12 rule still applies though.[/quote]
Pardon my ignorance, but what does 6/12 mean ? I have an older home (built in 1954). Some of the electrical has been updated, some not. I've been toying with the idea of replacing all the old with new. (The older lines are black and only have two wires; new is white with 3 wires) Any extented understanding of the Electrical Jargon would help! Thanks!!
Jilligoat
Jilligoat is offline   Reply With Quote
Old 02-07-2012, 07:27 PM   #9
Rewards Points: 264
For most residential rooms, no spot on the wall may be more than 6 feet along the wall from an outlet, disregarding open space from doors. Thus outlets can be spaced no more than 12 feet apart.
a_lost_shadow is offline   Reply With Quote
The Following User Says Thank You to a_lost_shadow For This Useful Post:
Jilligoat (02-07-2012)
Old 02-07-2012, 07:50 PM   #10
So, outlets need to be no more than 6 feet apart? (Unless there is a door..) Would that be correct?
Old 02-07-2012, 07:55 PM   #11
Rewards Points: 264
Not quite, outlets can be no more than 12 feet apart. The idea is you should be able to put a lamp with a 6 foot cord anywhere along the wall and reach an outlet (unless you hit a door).
Old 02-07-2012, 07:58 PM   #12
AHH!!! I see! Thanks so much!!
Old 02-07-2012, 08:03 PM   #13
Rewards Points: 264
I went looking for a picture, and found a better explanation and graphic at: Receptacles and 6 foot rules
Old 02-08-2012, 07:57 AM   #14
Rewards Points: 3,130
Just remember, the 6/12 rule is the MINIMUM number of outlets required. I always add more - you can never have too many outlets.
Old 02-08-2012, 08:32 AM   #15
Rewards Points: 166
Hmmm. Would like to see an entire wall covered by outlets. That be a sight.
Minus08 is offline   Reply With Quote
Tags
outlet
Converting switch to switch & constant power outlet BCeagle08 Electrical 4 01-29-2012 09:34 PM
No power after trying to change outlet - Help plz! dearly23 Electrical 22 12-27-2011 01:09 PM
switch has No power, outlet has Power exc3ll3nts Electrical 1 03-21-2011 06:20 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
No power at outlet furdur Electrical 7 12-19-2009 08:14 PM
