Power Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-28-2009, 02:55 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Take a picture of the red amd black dside of the outlet. The little tab should be broken between the two.
Old 03-28-2009, 03:01 PM   #17
do you yahoo or email?
OneLittleBoy is offline   Reply With Quote
Old 03-28-2009, 03:09 PM   #18
jbfan's Avatar
Rewards Points: 554
The white wire goes on the other side. It came out of a hole in the back of the outlet.
Since you do not have screws, push the wire back into on of the holes, then give a slight tug. If the wire comes out, put it into the other hole.
The best thing you can do is buy a new receptacle and replace the one you have by using the screws.
If you replace the outlet, make sure youo break the tab where the black an red wires go.
Yes I email, but this allows others that may have the same type of problem in the future.
Old 03-28-2009, 05:11 PM   #19
this discussion is good, and it really helped me. to moderator please close discussion because it works.
Old 03-28-2009, 05:28 PM   #20
joed's Avatar
Rewards Points: 13,354
It might work but I hope you fixed it properly.
1. Replace the receptacle.
2. The hole in the panelling needs to line up with the electrical box.
3. The recepatcle must screw to the electrical box. The way it is in the picture it doesn't look possible.
4. Use screw terminals not back stabs. Your same problem happens with them often.
No power in outlet sherben2 Electrical 16 03-19-2009 11:35 AM
Turned off power. Changed outlet. No power to entire house. pauly99 Electrical 39 03-06-2009 05:09 PM
power from outlet to switch lincoln85 Electrical 2 10-09-2008 12:04 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Outlet and light pigtailed to power. ok? skellies Electrical 2 06-24-2006 01:08 PM
