Power Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2009, 06:44 PM   #1
Power outlet
My power outlet for my food disposal suddenly doesn't work anymore. What could be the problem? I'm seeking help on how to fix this myself. If there is any help I would be happy..
OneLittleBoy is offline   Reply With Quote
Old 03-24-2009, 06:46 PM   #2
do you have a voltage tester?...that would be the first step...there may be a reset button on your disposal..but verify voltage first
NolaTigaBait is offline   Reply With Quote
Old 03-24-2009, 06:47 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Bad switch? Tripped breaker? What kind of testing equipment do you have.
Are you sure it's the receptacle and not the disposer? Most have a little reset button on the bottom.
wirenut1110 is offline   Reply With Quote
Old 03-24-2009, 06:51 PM   #4
Rewards Points: 510
I failed to mention back stabbed connections on the switch and/or receptacle that are not making contact.
Old 03-24-2009, 08:43 PM   #5
i have tested the voltage and it's around 65.0 and i tested other outlet and it's 120.0 i tested the diposal to another outlet elsewhere and it works fine....
Old 03-24-2009, 09:15 PM   #6
you may have a bad neutral...turn power off an pull the outlet out, verify the connections...also, the dishwasher is probably on the circuit as well...you'll just have to pull some stuff out and check...
Old 03-24-2009, 09:33 PM   #7
If the neutral is open-circuited it can't be the breaker.
If both the neutral and hot are open-circuited it's probably an upstream GFCI.
Use an incandescent bulb across your voltmeter leads to prevent it from reading phantom voltages (which read about 120/2 volts if the Romex has a ground wire in it, else they read about 120v).
Old 03-25-2009, 02:32 AM   #8
what do you mean by bad neutral?
Old 03-25-2009, 07:19 PM   #9
Does the dishwasher plug into the same receptacle?
Test voltage from hot to neutral (right slot to left slot if ground is down)
Then test from hot to ground.
This will tell you if the problem is on the hot (incoming, black) side or the neutral (return, white) side.
220/221 is offline   Reply With Quote
Old 03-25-2009, 09:08 PM   #10
we don't have a dishwasher.. we only have the receptical plugged in..
Old 03-25-2009, 09:33 PM   #11
you aren't being very helpful...pull the disposal outlet out and tell us what you see...check the disposal switch...
Old 03-25-2009, 09:41 PM   #12
Attached to your outlet you should see 3 wires. One is hot, one is neutral, and the other is your ground. When someone says you have "a bad neutral," they are trying to tell you that one of the wires (the neutral) might be functioning properly. There are a number of reasons why it might not be functioning properly, but first we need to make sure that's the problem.
Perform the tests that 220/221 suggested and post your results.
finnimus is offline   Reply With Quote
Old 03-28-2009, 03:22 PM   #13
This is what i see.. one wire is loose, but i don't want to plug in without letting u guys know... please help me..
Old 03-28-2009, 03:46 PM   #14
jbfan's Avatar
Rewards Points: 232
If that is the way it came out of the wall, the neutral wire is not connected to the outlet.
Are you sure the power is off? If so the connect the wire back to the screw.
It looks like it came from a back stab connection, so wrap it around the screw.
You should also cut some more of that cabinet out so the outlet fits inside the box properly, and put a cover on.
Old 03-28-2009, 03:52 PM   #15
it has one white wire, one red wire, and one black wire, and one ground.
No power in outlet sherben2 Electrical 16 03-19-2009 12:35 PM
Turned off power. Changed outlet. No power to entire house. pauly99 Electrical 39 03-06-2009 06:09 PM
power from outlet to switch lincoln85 Electrical 2 10-09-2008 01:04 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Outlet and light pigtailed to power. ok? skellies Electrical 2 06-24-2006 02:08 PM
