Power Outage To Upstairs... - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 12:10 PM   #1
Unhappy
Power outage to upstairs...
I was installing a new ceiling fan to replace an old one. from the box in ceiling there were 2 black hot wires twisted together, 1 white neutral, and 1 black w/white stripe. From the new fan there is a black, white, 2green grounds, and a black w/white stripe.
Initial wiring i did was all solid blacks + the black w/ white stripe from fan to the blacks on ceiling, put white to white, and then put my green grounds to the black w/white stripe from box since it was only wire left.... this caused the fan to "hum" when switch was on, tried on/off a few times then breaker popped in basement.
Tried a bunch of things the second time.... now realizing the grounds should have just went to a screw in the box not the black/white from house. I believe now it was too late. The black/white from the house is a constant hot wire, allowing the ceiling fan to run regardless of the light switch being on/off. (only 1 switch in room). My wife said she held the breaker over so because it kept tripping with the original wire setup, so i believe i now have a short somewhere. I now have no power to either upstairs bedroom. Checked power at the breaker w/ test light and there is power...
Dont know what to do next... how to i figure out where the power stops, its coming out of the main panel and does not make it all the way to my ceiling boxes anymore on the second floor....
Dextercat is offline   Reply With Quote
Old 04-15-2012, 12:17 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Shorting out the switch leg (black w/white stripe) could have blown the switch. I would first check the switch to see if it actually turns off, if it doesn't replace the switch.
Then I would check the splice of the two blacks up at the fan box to make sure they are still spliced together.
Other than that...I would think you blew a splice SOMEWHERE in the house.
Old 04-15-2012, 12:18 PM   #3
Rewards Points: 2,516
I take it the new fan has also a light kit with it.
How is this setup controlled. Do you have one single pole switch on the wall that controls both fan and light or do you have 2 separate single pole switches where one controls the light on the fan and one switch controls the fan motor?
hammerlane is offline   Reply With Quote
Old 04-15-2012, 12:22 PM   #4
Or do you have a double toggle switch?
Old 04-15-2012, 12:29 PM   #5
The fan is fan/light together. Controlled by single wall switch... The other bedroom across the hall has a single switch, fan/light combo. The light is controlled by the switch and the fan is controlled by the pull chain. The fan will run regardless of wall switch being on/off.
This makes me think the black/white wire from the house is a constant hot wire not controlled by switch. Initially when putting that with the black hot wires and then flipping the switch i think back-fed my breaker causing the trip, then when my wife held the breaker on when it wanted to trip i believe caused something to burnout somewhere....
bad photo but the neutral whites are not in the same nut as the grounds... i had to extend a wire from box to my neutrals and just used a white wire FYI
Old 04-15-2012, 12:34 PM   #6
Why not get a meter out and check the wires at the ceiling box and find out if any are ALWAYS HOT and which one is SWITCHED HOT
Old 04-15-2012, 12:36 PM   #7
k_buz's Avatar
Sounds to me that he has power on the blacks, and the black w/white stripe...I think he is going to find that the switch went bad when he shorted out the switch leg (black w/white stripe).
Old 04-15-2012, 12:36 PM   #8
cant check wires now because there is no power going to the ceiling box any more... something burnt out an i need to know how to find it and where to look. there is power at the breaker
Old 04-15-2012, 12:39 PM   #9
k_buz's Avatar
WHY IS THE WHITE TIED TO THE FAN'S MOUNTING BRACKET?!
Did you replace the box to a fan rated box?
Old 04-15-2012, 12:40 PM   #10
check for power at the switch??? Hopefully theres a neutral at the switch or at least a ground wire at the switch.
Old 04-15-2012, 12:40 PM   #11
yes fan box was there prior, there was a old fan there, its screwed into ceiling joust... and the white tied to the mounting bracket is not going to neutral... the grounds were not long enough so used a wire to just extend them... it happened to be white
Old 04-15-2012, 12:42 PM   #12
k_buz's Avatar
Doubt it, just because a fan was there before, doesn't mean the box is fan rated.
Old 04-15-2012, 12:44 PM   #13
better photo of wires
Old 04-15-2012, 12:44 PM   #14
ATfirst I thought all wires were under the one wire nut in the foreground. Just noticed the second wire nut in the photo. Which wires do you have under it? The greens plus the off-white?
Old 04-15-2012, 12:47 PM   #15
k_buz's Avatar
I think you need to start with taking down the fan and bracket, and take a picture of all the wires in the box.
To me, in the picture shown, it looks like the two wires tied together (and not wirenutted) should be the neutral.
Tags
breaker , ceiling fan , overload
cell/email notification in the event of a power outage jorourke Electrical 14 02-06-2013 05:46 PM
Low pressure after power outage cornick Plumbing 7 11-06-2011 01:49 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
no power upstairs only in basement and 1st floor. dstarks Electrical 1 12-14-2004 08:21 PM
