-   -   Power outage to upstairs... (http://www.diychatroom.com/f18/power-outage-upstairs-140343/)
Dextercat 04-15-2012 11:10 AM
I was installing a new ceiling fan to replace an old one. from the box in ceiling there were 2 black hot wires twisted together, 1 white neutral, and 1 black w/white stripe. From the new fan there is a black, white, 2green grounds, and a black w/white stripe.
Initial wiring i did was all solid blacks + the black w/ white stripe from fan to the blacks on ceiling, put white to white, and then put my green grounds to the black w/white stripe from box since it was only wire left.... this caused the fan to "hum" when switch was on, tried on/off a few times then breaker popped in basement.
Tried a bunch of things the second time.... now realizing the grounds should have just went to a screw in the box not the black/white from house. I believe now it was too late. The black/white from the house is a constant hot wire, allowing the ceiling fan to run regardless of the light switch being on/off. (only 1 switch in room). My wife said she held the breaker over so because it kept tripping with the original wire setup, so i believe i now have a short somewhere. I now have no power to either upstairs bedroom. Checked power at the breaker w/ test light and there is power...
Dont know what to do next... how to i figure out where the power stops, its coming out of the main panel and does not make it all the way to my ceiling boxes anymore on the second floor....
k_buz 04-15-2012 11:17 AM
Shorting out the switch leg (black w/white stripe) could have blown the switch. I would first check the switch to see if it actually turns off, if it doesn't replace the switch.
Then I would check the splice of the two blacks up at the fan box to make sure they are still spliced together.
Other than that...I would think you blew a splice SOMEWHERE in the house.
hammerlane 04-15-2012 11:18 AM
I take it the new fan has also a light kit with it.
How is this setup controlled. Do you have one single pole switch on the wall that controls both fan and light or do you have 2 separate single pole switches where one controls the light on the fan and one switch controls the fan motor?
hammerlane 04-15-2012 11:22 AM
1 Attachment(s)
Or do you have a double toggle switch?
Dextercat 04-15-2012 11:29 AM
1 Attachment(s)
The fan is fan/light together. Controlled by single wall switch... The other bedroom across the hall has a single switch, fan/light combo. The light is controlled by the switch and the fan is controlled by the pull chain. The fan will run regardless of wall switch being on/off.
This makes me think the black/white wire from the house is a constant hot wire not controlled by switch. Initially when putting that with the black hot wires and then flipping the switch i think back-fed my breaker causing the trip, then when my wife held the breaker on when it wanted to trip i believe caused something to burnout somewhere....
bad photo but the neutral whites are not in the same nut as the grounds... i had to extend a wire from box to my neutrals and just used a white wire FYI
hammerlane 04-15-2012 11:34 AM
Why not get a meter out and check the wires at the ceiling box and find out if any are ALWAYS HOT and which one is SWITCHED HOT
k_buz 04-15-2012 11:36 AM
Sounds to me that he has power on the blacks, and the black w/white stripe...I think he is going to find that the switch went bad when he shorted out the switch leg (black w/white stripe).
Dextercat 04-15-2012 11:36 AM
cant check wires now because there is no power going to the ceiling box any more... something burnt out an i need to know how to find it and where to look. there is power at the breaker
k_buz 04-15-2012 11:39 AM
WHY IS THE WHITE TIED TO THE FAN'S MOUNTING BRACKET?!
Did you replace the box to a fan rated box?
hammerlane 04-15-2012 11:40 AM
check for power at the switch??? Hopefully theres a neutral at the switch or at least a ground wire at the switch.
Dextercat 04-15-2012 11:40 AM
yes fan box was there prior, there was a old fan there, its screwed into ceiling joust... and the white tied to the mounting bracket is not going to neutral... the grounds were not long enough so used a wire to just extend them... it happened to be white
k_buz 04-15-2012 11:42 AM
Doubt it, just because a fan was there before, doesn't mean the box is fan rated.
Dextercat 04-15-2012 11:44 AM
1 Attachment(s)
better photo of wires
hammerlane 04-15-2012 11:44 AM
1 Attachment(s)
ATfirst I thought all wires were under the one wire nut in the foreground. Just noticed the second wire nut in the photo. Which wires do you have under it? The greens plus the off-white?
k_buz 04-15-2012 11:47 AM
I think you need to start with taking down the fan and bracket, and take a picture of all the wires in the box.
To me, in the picture shown, it looks like the two wires tied together (and not wirenutted) should be the neutral.
