Power Outage - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 05:47 AM   #1
power outage
Need some help with this one. Only have power downstairs to outlets and lights and same lights and outlets on same breaker upstairs are completely dead. Any ideas ir things to check for. Breaker not tripped, .
corywilmar is offline   Reply With Quote
Old 03-05-2013, 06:06 AM   #2
eastcoastsparky's Avatar
Rewards Points: 150
Loose connection, open up some recept and check before we move on to something else
eastcoastsparky is offline   Reply With Quote
Old 03-05-2013, 06:11 AM   #3
I checked the outlet where the issue seemed to occur and everything looked good there should I check every outlet.
Old 03-05-2013, 06:13 AM   #4
Rewards Points: 150
You could even try tapping on the wall around suspecting outlets, lights, switchs which can sometimes trigger that flicker if it is a loose connection
Old 03-05-2013, 06:13 AM   #5
There was two terminal post on each side of the outlet ,, I touched these wires and. Nothing no power.
Old 03-05-2013, 06:17 AM   #6
Rewards Points: 150
Do u mean with a meter theres no power , is the tab broken off in the middle of the hot terminals?
Old 03-05-2013, 06:34 AM   #7
I wiggled every thing around is it possiibley something wrong with breaker does a breaker seperate the house circuits without tripping both
Old 03-05-2013, 07:07 AM   #8
Rewards Points: 345
No. If you are sure that part is on and part is off and you are sure they are the SAME CIRCUIT, you have a loose connection somewhere. Look for back stabbed receptacles; often a culprit.
It could be at the breaker only if two wires are landed on it (one may be making connection, one not. VERY UNLIKELY.)
al_smelter is online now   Reply With Quote
Old 03-05-2013, 07:16 AM   #9
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Check all receptacles on that circuit working and not working you will most likely find a broken connection somewhere.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
LIghting Gas Fireplace in Power Outage?? Hossenfeffer HVAC 2 12-24-2012 10:14 AM
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 02:30 PM
power outage BAILEYANNE General DIY Discussions 12 11-28-2011 09:50 PM
Power Outage Issue? rbjones6 Electrical 13 05-24-2011 12:59 AM
