Old 01-11-2006, 07:30 PM   #1
power outage
While I wasn't here to see it and it sounds sketchy . . . . . we lost power downstairs and when the power went back on the fan started to work again but the lights attached to the fan never came back on. We did the obvious and changed the light bulbs. The lights dont work but the fan does. What are the odds that if I put a new light fixture on the fan, I can fix the problem? Thanks for the help.
jp66hill is offline   Reply With Quote
Old 01-11-2006, 08:01 PM   #2
johnh
power outage
take down the light fixture. it should have 3 to 4 screws holding it up. check connections and to see if ther's a short.
if all looks ok it might be in the switch, either at the wall or the fan.
if that doesn't do it check for power at the connection. if none, no repalcement will help and you might need to replace entire fan.
johnwhowe is offline   Reply With Quote
Old 01-15-2006, 01:18 PM   #3
power outage
Thanks for the advice. You are not going to believe this but . . . we lost power again on Friday night for 6 hours. When I woke up, the lights had mysteriously started working and have been fine since. Is there some kind of demon at work here or do you have a rational explanation for this?
Old 01-16-2006, 04:49 PM   #4
power outage
are you losing power in the entire house, including your neighbors or just in certain spots in your house? i was wondering if it was a bad breaker.
THEBIGPUNN is offline   Reply With Quote
Old 01-22-2006, 08:24 PM   #5
joed's Avatar
power outage
Is there a remote attached to this fan?
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 11:58 PM
Debugging Hot Water Heating System when on Standby Power hwitten Electrical 4 12-15-2006 09:47 PM
Running a generator for power outages tropic home Electrical 5 12-04-2006 09:22 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
