Power Outage - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2011, 08:13 AM   #1
power outage
The basement room and bathroom has no power. I tested the circuit breaker and the circuit breaker is good. I checked the GFCI outlet in the bathroom and the test button would not move, it seemed stuck. So I assume the GFCI outlet was bad. I changed the GFCI outlet and there is still no power. The wires are live because I tested them. But the indicator light on the GFCI outlet is off and I also plugged something in the outlet and still no power.
I also swapped the 'line' and 'load' wires just to make sure I didn't mix them up, and still no power.
Also, I tested the adjacent outlets in the bedroom and the wires aren't live when tested. Could it be a bad light switch? How else can I troubleshoot this?
Thanks in advance!
rtraveler is offline   Reply With Quote
Old 04-22-2011, 09:03 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Reconnect just the line side (power from the breaker panel) and retest. If it works you have downstream (wires on the load side) fault.
Coastal South Carolina
Old 04-22-2011, 09:24 AM   #3
joed's Avatar
Rewards Points: 12,902
Look for another GFCI that is tripped. Look in garage, outside, other bathrooms.
Old 04-22-2011, 10:59 AM   #4
I did and still no power or indicator light on the GFCI outlet. I also checked all the connections on all the outlets on the breaker. I also changed any backstab connections and screwed them in.
Old 04-22-2011, 11:00 AM   #5
I checked and there are no other GFCI oulets on the breaker.
Old 04-22-2011, 11:20 AM   #6
Licensed Pro
How did you test for live wires at the GFCI? If using a proximity tester, you may be getting a false signal. Use a test light, Wiggy, or multimeter. Suspect a loose connection at a still working receptacle on the same circuit.
Old 04-22-2011, 11:24 AM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
The bathroom and bedroom should not be on the same circuit.
How did you check for power before the gfci?
Check other parts of the house, you may have a larger problem.
jbfan is online now   Reply With Quote
Old 04-22-2011, 11:34 AM   #8
I used a voltameter, the light is green by default but turns red when it senses voltage. I see what you're saying with a false signal. I also used the voltage tester with the black and red prongs and it did not turn on.
There are NO working outlets on this circuit breaker so I'm scratching my head.
Old 04-22-2011, 11:37 AM   #9
The bedroom is actually just an open space in the basement. I checked the 'line' wires that feed into the GFCI and the voltameter detected voltage when the circuit breaker was on. But I also read elsewhere that it could be a loose white wire on another outlet. I checked and double checked all the outlets.
The rest of the house has power, it's just this one circuit breaker.
Do you think it could be a light switch? I hope so because I'm checking them now.
Old 04-22-2011, 11:56 AM   #10
Licensed Pro
Would not be a light switch unless the receptacles are controlled by a switch. It could be a connection inside a box with a switch. Could also be the neutral connection inside the panel. Have you tried swapping the black wire at the breaker with another breaker?
Old 04-22-2011, 12:11 PM   #11
A box with a switch? I'm confused by the above statement? So could it be a light switch or not?
Old 04-22-2011, 12:22 PM   #12
Licensed Pro
Not a switch but the connections in the box with a switch, or on the switch (in/out hot wires).
Old 04-22-2011, 03:26 PM   #13
joed's Avatar
There is an open connection on the circuit somewhere. If you are certain there is no problem in the breaker box then you need to start tracing the cable and find the break. Most likely it is an open connection in a junction box or other device.
Old 04-22-2011, 03:40 PM   #14
I checked the white wire connections in the light switch box and they are fine.
Old 04-22-2011, 06:19 PM   #15
dmxtothemax's Avatar
Rewards Points: 5,360
The fact that the light on the gfci is off says that power
is NOT getting thru the unit.
If the other outlets in the room go thru this unit
that explains why they are not getting power.
The gfci could well be faulty
Have you tried bypassing the unit completely ?
this will tell you for sure if its faulty.
If it is replace it.
But dont leave it connected without the cfci.
dmxtothemax is offline   Reply With Quote
Power Outage Issue? rbjones6 Electrical 13 05-24-2011 12:59 AM
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
