Power Out In A Room - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2010, 09:16 PM   #1
Power out in a room
I had a room lose electricity last night and this morning the power was back on, what happened.? I checked the switch and breaker it was okay.
I thought maybe a phase dropped out but what do I know? Weird happening
Wilhelm is offline   Reply With Quote
Old 12-31-2010, 09:57 PM   #2
joed's Avatar
Rewards Points: 12,918
Loose connection somewhere on the circuit. Could even be in the panel. Try something with a high current draw like a heater or the vacuum cleaner. That usually causes the problem to show up.
Old 12-31-2010, 10:50 PM   #3
Oldguy
Rehabber's Avatar
I see a lot of problems with 'backstab' receptacles having poor connections. Find out which circuit breaker this room is on, turn off breaker and find out how many other outlets are on this breaker. I recommend replacing all outlets that are backstabbed.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-01-2011, 09:06 PM   #4
I think JoeD and Rehabber are on to something. These receptacles are nearly 50 years old. One thing for sure, everything is Copper no Aluminum. Will get to testing this circuit and will report back. Thanks and Happy New Year.
Old 01-01-2011, 09:21 PM   #5
DIY staff
Rewards Points: 7,174
If you replace outlets --check each one to see if it is switched--look for the break off tabs between the power terminals on the old outlets.
It is a good habit to leave the old outlet on the floor under the newly installed ones----If you have problems you will be able to look at the old one and see if you forgot to snap off a tab.
Old 01-06-2011, 02:40 PM   #6
I turned on most of the lights in the room hooked up the Oreck Vacum Cleaner, turned it on and nothing happened everything worked just fine.
This brings me back to my "know nothing" thought that the power company may have been the cause of what happened. (i.e.) Phase drop?
But as I said before, what do I know.
PS Maybe our Oreck is to cheap and does not have the "butt" to shut er down.
Old 01-06-2011, 03:31 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,362
I would still do a thorough visial inspecion of all connecttions,
look for loose connections or overheated connections,
It is possible that the power company could be responsible,
But I would check any way, to provide peace of mind.
dmxtothemax is offline   Reply With Quote
Loss of power and AFCI tripping Sacslc Electrical 14 11-14-2010 09:12 PM
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 03:19 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Power in a server room pcampbell Electrical 1 06-24-2008 10:53 PM
