Power Out In ONLY One Room...but Breaker Not Tripped - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-12-2012, 02:24 PM   #16
Oso954's Avatar
Rewards Points: 1,632
Originally Posted by RH913RH View Post
....The line side is the terminal on the breaker to which the black or red wire is attached. ......
The red or black wire side is the LOAD side of the breaker.
(The exception would be when you are backfeeding a breaker)
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
RH913RH (10-12-2012)
Old 10-13-2012, 09:57 AM   #17
So went and played 'Sparky the amateur electrician' and didn't find anything backstabbed or out of the ordinary. Unfortunate as I'm not sure where else to look.
Any thoughts? Otherwise I think I'll need to call a proper electrician to come and look at this
weber78 is offline   Reply With Quote
Old 10-16-2012, 03:44 PM   #18
Is it possible that the wire into the Breaker Box came loose?
I'm thinking that I remove the breaker cover and look for any dangling wires or anything that is loosely attached.
Thoughts?
Old 10-16-2012, 05:15 PM   #19
Oso954's Avatar
Possible, but unlikely.
I don't think you are ready to be poking around inside a breaker box. Hire an electrician to trouble shoot your problem.
He may pull the panel cover.
If not, you can ask him to. But be prepared to pay him for the education.
Old 10-13-2015, 07:33 PM   #20
Rewards Points: 2
loss of power in one room only
wife tried to turn on lites in bathroom, flash and out. breaker did not trip. lost power to half receptacles in adjacent bedroom. checked the lite switch she used. has 120 vac on both sides of the switch whether on or off. adjacent switch to exhaust fan, same test, same result. nothing works
bobbydean411 is offline   Reply With Quote
Old 10-13-2015, 08:11 PM   #21
Rewards Points: 516
It didn't hit me till I saw the year on this one. If you're looking for help you might want to start a new thread
Arrow3030 is offline   Reply With Quote
The Following User Says Thank You to Arrow3030 For This Useful Post:
r0ckstarr (10-14-2015)
Tags
bedroom , breaker , electricity , newbie , no power
No power in 1 room (3 outlets) breaker appears to be fine RR. Electrical 5 11-01-2011 06:09 PM
No power and no breaker tripped temporarily jritkes Electrical 2 06-16-2011 01:05 PM
breaker not popped but no power natrensland Electrical 29 06-11-2011 12:43 PM
Loss of power and AFCI tripping Sacslc Electrical 14 11-14-2010 09:12 PM
Lost power to half the room. imfocused Electrical 17 04-10-2010 06:10 PM
