Old 06-17-2010, 01:20 PM   #1
Power Out
I accidentally reversed polarity when I was using my table saw and the power went out on that circuit. The circuit breaker did not trip but the power is out. Also the power went out on three other circuits without tripping the circuit breaker. The rest of my circuits are working. Any idea what happened?
Gandalf is offline   Reply With Quote
Old 06-17-2010, 01:50 PM   #2
Power Out
Maybe you tripped the master breaker on a subpanel?
operagost is offline   Reply With Quote
Old 06-17-2010, 03:08 PM   #3
It was a dark and stormy
Yoyizit's Avatar
Power Out
I don't know how you can reverse polarity on an AC circuit but I'd think a marginal wirenut or connection opened.
You may still get a voltage reading with no load on this circuit.
Old 06-17-2010, 03:45 PM   #4
Electrical Supplier
Power Out
do you get voltage to ground on anything?
LyonsElecSupply is offline   Reply With Quote
Old 06-17-2010, 04:03 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Power Out
You want to explain to us what this means exactly.
Old 06-17-2010, 04:38 PM   #6
Power Out
yeah i'm confused too. with respect to A/C current, polarity doesn't matter, just phase.
NitroNate is offline   Reply With Quote
Old 06-17-2010, 05:38 PM   #7
Power Out
Does a table saw have a reverse rotation, for example to unjam with?
Perhaps he meant throwing it in reverse without waiting for it to come to a stop.
Long long time ago, if a streetcar's brakes failed, the motorman might throw it in reverse to make an emergency stop. (Also called bucking the motors)
This usually causes a tremendous power draw at least for a moment.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-17-2010, 06:47 PM   #8
I=E/R
a7ecorsair's Avatar
Power Out
And phase only matters if there are three
a7ecorsair is offline   Reply With Quote
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 04:19 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 09:17 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
