Power Out - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2006, 12:44 AM   #1
Power Out
I put new can lights into my unfinished basement the otehr night, and then hooked up the light sin another room from that circuit. The can lights worked fine, untill i hooked up the other florescents, the florescents came on tehn everythign went out the breaker did not trip, but there is no power from the main line to the light fixtures. what is the problem did the breaker go bad without tripping, what do i need to do?
iowaump is offline   Reply With Quote
Old 08-09-2006, 03:16 AM   #2
Three possibilities come to mind right away.
1 loose connection some where.
2 breaker sometimes trip and it is not obvious. turn off all the breakers one at a time and turn them back on.
3 there is s gfi somewhere in the circuit that has tripped.
jwhite is offline   Reply With Quote
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 10:58 PM
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 07:12 PM
Running a generator for power outages tropic home Electrical 5 12-04-2006 08:22 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
