Power Or Not? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 09:30 PM   #1
Power or not?
I have 4 recepticles on one circuit in bedroom. I check my circuit on all of the recepticles and the light comes on. If I plug anything in (I have tried a few different things) none will work in any of the circuits. Any idea what is going on?
wvboycleve is offline   Reply With Quote
Old 03-15-2011, 09:32 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
you need a plug tester, test the plugs
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-15-2011, 10:54 PM   #3
Rewards Points: 506
What is a plug tester?
jlmran is offline   Reply With Quote
Old 03-15-2011, 11:28 PM   #4
Scared Electrician
http://www.homedepot.com/Electrical-...atalogId=10053
Old 03-16-2011, 11:00 AM   #5
Mad Scientist
What do you mean by this: "I check my circuit on all of the recepticles and the light comes on."?
Are you testing for power with one of those non-contact voltage detectors? If it's showing power at the hot slot on each outlet, than you either have a loose connection, or an open neutral.
Those voltage detectors are fairly sensitive, and will pick up power on a wire even if the connection is too loose to handle any load.
Get a plug-in tester as Saturday Cowboy suggests. If it is a case of a neutral wire being broken or disconnected somewhere, that tester will tell you.
McSteve is offline   Reply With Quote
Old 03-16-2011, 11:11 AM   #6
I=E/R
a7ecorsair's Avatar
What are you using? Is it a neon test light? These don't put much load on a circuit so a loose connection may pass enough power to illuminate the lamp but you can't tell much from this. A 100 watt bulb in the same receptacle may not light.
a7ecorsair is offline   Reply With Quote
Old 03-16-2011, 07:29 PM   #7
Rewards Points: 506
Originally Posted by Saturday Cowboy
This is a receptacle tester. A plug is what is placed into a receptacle (or socket).
Outdoor Hot Tub / Overhead Power line issue scottwilliamson Electrical 3 02-12-2010 10:37 AM
Devices to save on phantom power fetzer85 Electrical 7 12-04-2009 08:03 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 07:45 PM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 12:16 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
