Power On, No Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2005, 08:23 AM   #1
Angry
power on, no lights
just bought a fixer upper and can't seem to get overhead light or receptacles to work in one bedroom. Small two pronged tester "lights" on B/W and B/ground wires in overhead and when plugged into receptacle. ohmmeter shows 120v at all these junctions. on/off switch does control "power" to overhead wiring. I am so dumb please help !! or i may grab the white and black wires to see if they are reaally hot!! thanks for your help
barrybo2 is offline   Reply With Quote
Old 11-05-2005, 08:17 AM   #2
power on, no lights
i see alot of people have read my initial question but have had no response. Grabbing the wires was a joke! i really have this problem and need help or suggestions thanks!
Old 11-05-2005, 10:09 AM   #3
Remodeler
MinConst's Avatar
barry,
If the wires test good then it must be in the fixtures. The duplex outlets might be so worn that they no longer make contact with the lrongs on a plug. Change the duplex outlet with the power turned off.
Same thing with the overhead light. If the wires test good turn off the power at the breaker panel for that circuit and replace the fixture. Be sure the power is off properly or your joke will become reality.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Hall lights don't work. jagrunner2602 Electrical 13 05-02-2007 11:08 PM
Pulling power for new lights TerryL Electrical 2 10-26-2006 08:08 PM
power source for recessed lights Jackman Electrical 1 09-18-2006 07:30 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
