Power For New 20x20 Detached Garage, NJ. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-09-2014, 08:37 AM   #31
Licensed electrician
Rewards Points: 1,876
Originally Posted by electures View Post
The Ufer ground is not "reguired". However, if it is available it shall be used. Ground rods are all you need.
One way this is interpreted is if the footer has rebar it is available and someone will be chipping concrete to make the connection if not done before the pour.
Old 01-09-2014, 08:52 AM   #32
Thanks for the quick reply. I'm going to start the conduit runs soon if the ground thaws enough. Part of my trench will be under a section of driveway, which is still dirt right now. Is 18" deep enough for the whole run?
I did not set the conduit into the slab.
I will be coming up outside / next to the garage wall and plan to ell through the wall as low as possible, then ell up and go into the bottom of the load center. I believe I need sch 80 at the exposed feed into the building to the panel.
Is sch 40 ok for the rest, including the run along the bottom of the floor joists in my basement to the main panel?
jtcnj is offline   Reply With Quote
Old 01-09-2014, 08:58 AM   #33
i've always approached this as a building is not 'existing' until it has an occupancy permit or in the case of a garage, a final inspection. if the concrete guys bury the rebar before the electrician can bond it, not at all unusual for the inspector to require it to be chipped away and bonded.
itsnotrequired is offline   Reply With Quote
Old 01-09-2014, 11:52 AM   #34
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Agreed. That is why here in The Peoples State of New Jersey the building Inspector is charged with the rebar inspection.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 01-10-2014, 06:25 PM   #35
I bumped these up from earlier posts, unless I missed a reply, could someone clarify these items:
Is the plastic threaded bushing screwed on the end of the box connect at the tops of my stubs an acceptable entry, or do i need the emt to romex clamp style connector?
When I have to run romex perpendicular across the trusses, can I staple to the top of the ceiling joist member of the truss or must (or can) I drill it? Can you drill truss assemblies at all without affecting the structural integrity?
Is sch 40 ok for the rest, including the run under the driveway and along the bottom of the floor joists in my basement to the main panel? These don't seem to be exposed to possible damage.
Do I need an expansion sleeve for the stub up from the trench to above ground, which will be probably less than 3' long?
Part of my run will be under what will be driveway, now still dirt. Since this is for a single family dwelling, is 18" depth still correct, or do I need to go 24"?
Need help planning an electrical service upgrade to detached garage PaulTurner Electrical 2 04-05-2011 03:43 PM
wiring 100A to detached garage snowman Electrical 4 11-28-2009 04:53 PM
Subpanel - detached garage without a floor SAS Electrical 12 03-05-2009 11:42 AM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 12:08 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
