Power To My Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 04:22 PM   #1
Smile
power to my garage
want to put a sub panel in my garage can i put 3 6ga and 1 8ga ground and 2 10ga wires in 3/4 pvc does the ground have to be green or can i tape it green thanks
toddman0 is offline   Reply With Quote
Old 11-27-2010, 06:00 PM   #2
Mad Scientist
Ground has to be green. Should be no problem to find #8 in green.
Is this a detached garage? What are the two #10s for?
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
toddman0 (11-27-2010)
Old 11-27-2010, 06:12 PM   #3
2 10s for 120 volt solar disconnect garage is detached 40 feet i have solar grid tie inverter in garage need the 10s for disconnect on house by meter.is it up to code for that many wires thanks
Old 11-27-2010, 11:10 PM   #4
No. You can only fill the conduit to 40% of it's cross-sectional area.
For THHN/THWN conductors, you would need minimum of 1" Schedule 40 PVC conduit, but PVC conduit is cheap - I would put in 1-1/2".
Willis
williswires is offline   Reply With Quote
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 04:19 PM
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
garage door opener power handifoot Electrical 4 11-23-2008 08:30 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 03:51 PM
