Power From Main Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-10-2013, 07:20 PM   #1
Power from Main Panel
Should the individual leads (2/0 Alum.) be in the electrical PVC tubing leaving the Main panel before going out the wall then underground in PVC tubing to my garage?
Ed62 is offline   Reply With Quote
Old 05-10-2013, 07:32 PM   #2
Rewards Points: 512
If I'm understanding your question, I believe they can run without conduit within that wall. An LB is generally used on the exterior wall from the 18" trench.
Installation is the Reverse of Removal.
Old 05-10-2013, 08:05 PM   #3
Electrical Contractor
kbsparky's Avatar
If you are installing individual wires, then yes, they need to be in conduit all the way.
-KB
The Following 3 Users Say Thank You to kbsparky For This Useful Post:
Ed62 (05-10-2013), Jim Port (05-10-2013), stickboy1375 (05-10-2013)
Old 05-10-2013, 08:06 PM   #4
My main panel is mounted on the cellar wall(foundation) of course so I'm talking about the leads coming out of it going up the wall( not in it) where it will then go outside just above the wood plate through an LB.
Old 05-10-2013, 08:28 PM   #5
Rewards Points: 512
What type of wire are you using (per kbsparky's post)?
The Following User Says Thank You to sirsparksalot For This Useful Post:
kbsparky (05-10-2013)
Old 05-10-2013, 10:03 PM   #6
Using number 2/0= 2 ought Aluminum for running in PVC.
Old 05-10-2013, 10:21 PM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,860
Not sure of code call/req, but even in SER cable , my county required it in schedule 80.... to protect against damage on a short interior run.
MTN REMODEL LLC is online now   Reply With Quote
Old 05-10-2013, 11:04 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
They are starting to require that more around here, but here is my issue, fittings are still not sch. 80 type, and those are the parts that most often get broken, lets face it, how many cracked LB's do you see vs. a section of PVC?
Also, if something were to hit sch. 40 conduit, doesn't anyone think that force will also smash sch. 80? I just can't grasp the logic of why they require sch. 80.
Old 05-10-2013, 11:14 PM   #9
" Euro " electrician
frenchelectrican's Avatar
The biggest issue which part I do argee with vous ( you ) is that the sch 40 fitting with sch 80 pipe that logically the sch 40 fitting will break first before the sh.80 pipes will do.
Now for the PVC LB's I have see couple of them cracked it don't matter if North Americian verison or European verison both have same result.
Merci,
Marc
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Back up generator for main panel in power outage. Greenie Electrical 44 07-29-2015 10:57 PM
Grounding main panel Arky217 Electrical 5 03-08-2012 06:10 AM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
